Old 03-19-2015, 02:58 PM   #1
ExNorth
ExNorth has a spectacular aura aboutExNorth has a spectacular aura about
1997 SL1
Default Need to find a spot to run a power line for a Subwoofer.
The title says it all. I'd like to avoid drilling a hole in the firewall.. Is there any known spot that I can safely run a power line from the battery, through the firewall to the back of the trunk? Some cars have spots that can fit a power line through. I am hoping some of you more advanced members can help me out.
Thanks!
Add to ExNorth's Reputation
Rate the quality of this post and help ExNorth reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ExNorth is offline   Reply With Quote
Old 03-19-2015, 10:25 PM   #2
Default Re: Need to find a spot to run a power line for a Subwoofer.
If you have an automatic do like everyone else has and cut a hole in the clutch master cylinder grommet.
If you have a manual do do like everyone else has and cut a hole in the grommet with the PCM wires near the brake booster.
Old 03-20-2015, 11:46 AM   #3
Foment_life
Foment_life is on a distinguished road
Foment_life's Avatar
I ran mine through the rubber boot with the main wire loom by the brake booster. I will take pictures to post Monday if you're unsure what I'm referring to exactly.
As for running it after that though, I'd imagine running it up the driver's side, under the door trim all the way to the trunk is the easiest way to go, as it is in nearly every other vehicle ever made. I have a 10" low-profile sub in the back seat, so I ran mine under the center console.
1999 Saturn SL2 186K **Daily Driver**
2007 Toyota Matrix XR 1.8L 91k //The Out-of-towner\\
1994 Suzuki Sidekick 185k <<Wife's Go-Kart>>
Add to Foment_life's Reputation
Rate the quality of this post and help Foment_life reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Foment_life is offline   Reply With Quote
Old 03-20-2015, 11:54 AM   #4
Foment_life
As for running it after that though; I'd imagine running it up the driver's side, under the door trim all the way to the trunk is the easiest way to go, as it is in nearly every other vehicle ever made. I have a 10" low-profile sub in the back seat, so I ran mine under the center console.
Old 03-20-2015, 04:55 PM   #5
ExNorth
1997 SL1
Yes please do provide some pictures! I really appreciate the help and replies from both of you!
Old 03-20-2015, 09:12 PM   #6
wi111y
wi111y is on a distinguished road
1995 SL
1995 SW2
I ran mine through that main grommet also. You you can use a long screwdriver and poke a small enough hole through it that the power wire fits snugly. Then run it back under all the door trim all the way back to the trunk.
'95 SL 5 Speed 220k - DD
'95 SW2 5 Speed 230k - Gone!
'95 Camaro Z28 - Project
'00 Tahoe Z71 - Truck stuff
Add to wi111y's Reputation
Rate the quality of this post and help wi111y reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
wi111y is offline   Reply With Quote
Old 03-24-2015, 11:22 AM   #7
Foment_life
Okay, so here's a quick snap through of what I did.
I didn't buy a battery tap, I used the power terminal off the UHJB, was much easier and there was plenty of room without modifying anything.
You see 2 wires because I ran a dedicated lead for my head unit as well as the subwoofer. Every connection in the wiring here is soldered, wrapped in heat shrink, and in many cases, electrical tape on top of it.
I put my wiring through this main boot here, next to the wire loom for just about everything in the car. Maybe you want to go a little farther away from the main loom when you push through here.
I cut a wire coat hanger down and duct taped the power cable to it. Works like a charm.
Here you can see from the driver's foot well how I ran mine. There's plenty of room to run the wire up through a gap in the metal frame here to keep it out of the way. It doesn't interfere with anything while I'm driving or when I am using the ODBII port.
There's a bit of insulation etc, to contend with when you have to find the wire hanger you push through. You might end up hitting the insulation and not coming through cleanly next to the wire loom that's already in place. Just follow it to the root and fish around next to it with your fingers, you'll find what you pushed through.
Old 03-25-2015, 06:17 PM   #8
Upstate Saturn
Upstate Saturn has a spectacular aura aboutUpstate Saturn has a spectacular aura aboutUpstate Saturn has a spectacular aura about
Upstate Saturn's Avatar
2001 SL2
Great photos, will be very helpful to me, thanks!
2001 SL2 manual - original owner - remanufactured engine at 228k miles, December 2015
1992 SL1 - bought used in '93, totaled in '00 at 170k miles, drove it cross-country a lot!
Add to Upstate Saturn's Reputation
Rate the quality of this post and help Upstate Saturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Upstate Saturn is offline   Reply With Quote
Old 03-26-2015, 09:45 AM   #9
Foment_life
Glad I could help!
If you're installing (or have already installed) an aftermarket CD player/head unit, seriously consider taking the stereo's constant power off the F5 circuit. Running a 14-16 gauge fused wire when you install the subwoofer takes like... 5 extra minutes and will take some load off the circuit that runs your fuel pump.
trying to find AC inlet line Solion L-Series Tech 1 04-20-2012 10:42 PM
Connecting Subwoofer Power Cord to Battery Blackzilla L-Series General 1 02-02-2008 10:19 PM
Amp power line placement mpbrown18 Vue General 4 03-01-2006 02:33 PM
Can't find the power steering fluid resivor? jdt141 Ion General 17 12-16-2004 09:51 PM
Massive flat spot/loss of power Worknclassbug S-Series General 13 07-04-2004 02:30 PM
