Old 03-18-2015, 02:52 PM   #1
Wallyb87
Wallyb87 has a spectacular aura aboutWallyb87 has a spectacular aura about
Dazed p0107 DTC
The other night I was playing around with my 2004 Ion 2.2 QC, burned out a little, and somehow managed to snap the Refrigerant Pressure Sensor in half. Car threw the p0107 DTC and started running rough and hesitating. Upon finding the broken sensor, I replaced it, and the car ran better but still had hesitation and the CEL was still on. I replaced the MAP sensor, believing it to be the problem. After replacing the MAP sensor, the car will not start. It turns over strong but just can't seem to run. I've tried searching these forums and others, but my problem seems to be unique. Any input would be greatly appreciated!
Add to Wallyb87's Reputation
Rate the quality of this post and help Wallyb87 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Wallyb87 is offline   Reply With Quote
Old 03-19-2015, 01:03 PM   #2
Default Re: p0107 DTC
Not much info is given here. The a/c pressure sensor affects the a/c system only - a broken one simply won't affect a/c operation unless the break leaks refrigerant gas and oil. This has no effect on the engine creating P0107; map sensor issue.
1-What does "burned out a little" mean?
2-Mileage, maintenance done, parts replaced?
Old 03-19-2015, 05:44 PM   #3
Wallyb87
Turned out to be a loose electrical connection at the alternator, which I had replaced about a week ago. Thank you for the fast reply.
PLEASE HELP!!! Code p0107!!! Acrite3404 S-Series Tech 5 07-12-2014 11:38 AM
