Old 07-12-2016, 04:18 PM   #21
04RDLN
04RDLN is on a distinguished road
04RDLN's Avatar
2004 VUE Red Line
Default Re: 2005 FWD Rear Disc Conversion
Does anyone know if there is an option for the awd vues? My subframe rusted and cracked so I may as well do the conversion if I need to replace it.
http://www.cardomain.com/ride/2241358
Add to 04RDLN's Reputation
Rate the quality of this post and help 04RDLN reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
04RDLN is offline   Reply With Quote
Old 07-12-2016, 07:17 PM   #22
billysvue
REad the post prior to yours.
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Add to billysvue's Reputation
Old 07-31-2016, 10:43 AM   #23
blacknbluevue
blacknbluevue is on a distinguished road
blacknbluevue's Avatar
2007 VUE 2.2L
Originally Posted by ED1 View Post
Also need rear axle tips from the 2 cars..You have to dissassemble the axles to get the tips..
Why are axle tips needed? Is it for the wheel studs? Did the equinox only have rear discs in AWD models?
1991 SL1 5 sp 120K mi SOLD
2004 Ion 2 L61 5 sp 155K mi SOLD
2005 VUE L61 5 sp 181K mi LOST IN TS JOAQUIN 10/2015
2007 VUE L61 5 sp 120K mi
Add to blacknbluevue's Reputation
Rate the quality of this post and help blacknbluevue reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
blacknbluevue is offline   Reply With Quote
Old 09-07-2016, 08:38 PM   #24
Indyl03
Indyl03 is on a distinguished road
2004 VUE 2.2L
Don't understand need for the tips on my base setup since the stock hubs are wide open in back. I figure the hole is for awd...
Add to Indyl03's Reputation
Rate the quality of this post and help Indyl03 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Indyl03 is offline   Reply With Quote
Old 09-07-2016, 09:23 PM   #25
billysvue
Ditto
'17 Suby Forester
Old 02-13-2017, 02:48 PM   #26
ED1
ED1 is on a distinguished road
Sorry havent been on here for awhile.
The Axle tips are needed for the Hub Bearings to last. Without the Axle Tips bearing will not last.
Saturn Stock Axle tips are wider than the Equinox. You can't use the the saturn stock axle tips they're wider..
2007-2009 Equinox FWD/ AWD both came with REAR DIsc..
Add to ED1's Reputation
Rate the quality of this post and help ED1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ED1 is offline   Reply With Quote
Old 09-05-2017, 03:41 AM   #27
Tobacconist
Tobacconist is on a distinguished road
Will this modification work with the Vue's ABS system?
I think the 2007+ Equinox and 2008+ Vue used a different ABS system.
Also will the 2002-2007 Vue rear wheel bearing/hub bolt onto the Equinox knuckle?
Add to Tobacconist's Reputation
Rate the quality of this post and help Tobacconist reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tobacconist is offline   Reply With Quote
Old 05-29-2018, 04:01 PM   #28
john21
john21 is on a distinguished road
parts needed to do conversion:
2007-2009 Equinox complete rear trailing arm, E-brake cables, Rear Axle Tips, Axle nuts.
2008-2010 Saturn vue complete rear trailing arm, E-brake cables, Rear Axle Tips, Axle nuts.
Hello,
I recently came across your post regarding the rear drum to disk brake conversion. I know that was a long time ago but I do have a few questions about it.
First, I see from the post that I will need the e-brake cables. I was wondering if you meant the WHOLE cable including from where the brake is to where the handle is or did you mean just a part of the line?
Second, did you just unbolt the regular brake line from where the brake line meets the brake hose and then bold the new one on or did you replace the entire brake line with the new one?
Thanks so much.
Add to john21's Reputation
Rate the quality of this post and help john21 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
john21 is offline   Reply With Quote
Rear Disc Conversion SL2-Guy S-Series Mods 4 08-17-2007 07:02 AM
Rear Disc Conversion 92[SL2] S-Series Tech 17 03-20-2007 12:01 PM
Rear disc conversion - no how-to? sps SOHC S-Series Tech 46 09-08-2005 09:24 AM
Rear Disc Conversion SLeepr Classifieds 4 12-03-2003 07:51 PM
Rear disc conversion... need help! MeaNGreeNSL2 S-Series General 2 07-11-2003 02:11 AM
