Old 03-15-2015, 07:13 PM   #1
mrcoachdavis
mrcoachdavis has a spectacular aura aboutmrcoachdavis has a spectacular aura about
Default 6t75 Solenoid removal
Hey all. My first time being on here. Hope there is help out there. Having trouble with a connector so How do I remove the wire harness retainer from the control valve body cover stud and disconnect the control valve body Transmission Control Module (TCM) electrical connector? Picture or video would be great.
Add to mrcoachdavis's Reputation
Rate the quality of this post and help mrcoachdavis reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mrcoachdavis is offline   Reply With Quote
Old 03-15-2015, 07:33 PM   #2
mrcoachdavis
Default Re: 6t75 Solenoid removal
Added a picture
Old 03-15-2015, 10:29 PM   #3
The lever arm (different shade grey from the connector) is moved to the right in your picture. On the right side of the lever is a lock tab that you press down to allow the lever to be moved to the tight. As the lever moves to the right it is supposed to lift the connector out of what it is plugged into. In real life you may need to help it along by wiggling the connector outwards as you move the lever.
Add to ssicarman's Reputation
Old 03-25-2015, 05:54 PM   #4
mrcoachdavis
Thank You. I think I will give it a try on Saturday.
6T70 6T75 Transmission Repair transtech49 Classifieds 0 12-31-2014 04:41 PM
Help! Power steering pump EVO solenoid removal Upstate Saturn S-Series Tech 11 12-17-2014 07:55 AM
saturn outlook 6t70&6t75 3-5-r failure satlite440 Outlook General 19 01-15-2014 08:55 PM
1-2 Shift solenoid removal rower Vue Green Line 0 05-10-2013 11:45 AM
Outlook Tranny = 6T75 GR898SL2 Outlook General 13 05-19-2006 06:34 AM
