Old 03-06-2015, 12:07 PM   #1
Logancolerose
Logancolerose is on a distinguished road
2001 SC1
Question Sun roof ideas
Hey guys I recently bought a 2001 SC1.
The sun roof has a leak.
I tried to fix it, but at this point I just want the leak sealed.
I used Gorilla Clear Repair which looks fine to me.
But my car has too much moisture in it even after drying in the sun for a day.
Now the tape has moisture on the back side.
I have the windows down again and am hoping the tape dries and keeps working.
I was wondering if anyone has used silicone, or any other fix that has worked for this? I am more worried about a water tight seal than looks but if I can have both is prefer it.
Thanks for the help.
Add to Logancolerose's Reputation
Rate the quality of this post and help Logancolerose reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Logancolerose is offline   Reply With Quote
Old 03-06-2015, 03:41 PM   #2
Chub
Chub will become famous soon enough
Chub's Avatar
Default Re: Sun roof ideas
Where is your sunroof leaking?
I know you said you had given up trying to fix it but depending on what you have done it may not take too much more to keep it from leaking.
However, silicone sealant around the glass is the standard course of action for a sunroof that you don't want to leak anymore. The best way to put it on would be using a caulk gun from the hardware store and lay a nice bead between the rubber on the glass and the roof of the car. This fix will be mostly permanent because getting the silicone off later is a major pain. Make sure you are pretty much set that you never want it working again before you go this route.
1995 SC2: Back on the road again after my second engine rebuild in two years.
Add to Chub's Reputation
Rate the quality of this post and help Chub reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Chub is offline   Reply With Quote
Old 03-06-2015, 04:44 PM   #3
trottida
trottida's Avatar
To add to that, there is a silicon caulk that is removable. DAP Seal n Peel is one example of this type of caulk.
Current rides
:canada:
Add to trottida's Reputation
Old 03-09-2015, 01:10 PM   #4
Logancolerose
2001 SC1
I used gorilla clear tape for starters and its working so far, if it ends up failing I'll go the silicone route. Thanks for the help. It seems I'm going to prob need a battery now, its died twice while parked, and no date on the battery, but it looks old.
Old 03-09-2015, 01:32 PM   #5
lamping.ap
lamping.ap will become famous soon enoughlamping.ap will become famous soon enough
Did you clean the drain tubes? If they clog, the water will spill over the pan onto the headliner, into the car.
Add to lamping.ap's Reputation
Rate the quality of this post and help lamping.ap reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lamping.ap is offline   Reply With Quote
Old 03-09-2015, 01:41 PM   #6
Logancolerose
2001 SC1
I never even looked for the drain tubes, due to the sun roof not even being able to close all the way, I took it apart and got it set level, then screwed it back in, and then let it dry out in the sun, then I put one clear layer of that gorilla tape around it, its barely noticeable. And so far its held up. Not sure what to expect out of it yet, but it says it gets stronger over time. I figured the tape would clean off easy if I ever felt like fixing the thing, with a little adhesive remover.
Roof Leak!! Roof Rack the culprit? tmckinn Outlook General 77 06-26-2013 12:39 PM
Sun Roof/moon roof cover stuck raj49 S-Series General 2 10-07-2012 10:00 PM
Roof rack for 2007 Vue w/o Chrom Roof Rails ewmaher Vue General 11 06-16-2009 08:41 AM
Panoramic roof......twice the cost, twice the trouble of a regular roof? comcardi Aura General 10 08-04-2006 10:31 PM
Really bad roof leak due to rusting. Any ideas? petemcs S-Series Tech 5 01-04-2003 01:18 AM
