Old 02-28-2015, 11:40 PM   #1
proffx
proffx is on a distinguished road
Default passenger door handle assembly 1997 SC1
for some reason I can't locate the spring loaded outer door handle assembly on the interlink for part replacement. anyone know of a good site for one? the outer door handle broke off at the assembly inside the door. I bought one used from ebay and was sent a broken one and the wrong size
1997 sc1 - I'm only looking for the spring thingy that the outer handle attaches to.. thanks for any help!
Add to proffx's Reputation
Rate the quality of this post and help proffx reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
proffx is offline   Reply With Quote
Old 02-28-2015, 11:46 PM   #2
Default Re: passenger door handle assembly 1997 SC1
Not 100% sure what you need but #14 has a part number (21098554) and about $20 shipped price ($15 plus s/h) from NallyGMC
http://parts.nalleygmc.com/showAssem...rimLevel=15285
If it's the metal tabs that handle bit goes into that broke, they're easy to replicate with sheet metal, a drill and 2-3 rivets per side of handle. Seemed to be a common problem on 1st gen coupes which I've had 2 of, the 2nd gen's appear to use the same style handle.
Old 03-01-2015, 09:08 AM   #3
proffx
thank you sir, the part I pried out from the tabs did have a p/n on it but the internet didn't provide much. I will check out your info! - ken
Replacing Parking Brake Handle Assembly RalliArt16 How-To Library 7 06-23-2011 11:24 AM
Door Handle Assembly! It's driving me crazy. ns087 S-Series Tech 7 09-28-2007 09:39 PM
How to screw handle over passenger door tremba S-Series General 4 07-31-2006 08:26 AM
Replacing Parking Brake Handle Assembly RalliArt16 S-Series Tech 0 10-27-2005 06:02 PM
how to removeoutside door handle on 1997 saturn mikeyshane331 S-Series Tech 8 02-28-2005 08:44 PM
