Old 02-27-2015, 01:30 PM   #1
threecaster
threecaster is on a distinguished road
Default 2007 Vue radio receiver recalibration procedure
Hey Y'all.
I've got a 2007 Vue.
It has the radio w the XM and the 6 CD changer.
The FM reception is more or less null. Everything else on radio unit seems fine.
I can't find/remember the exact TSB, but it said something to the effect of:
"do NOT:
change the radio
change the antenna cable
change the antenna
DO:
have the radio recalibrated"
Does anyone have the ~procedure~ (step by step) to accomplish this calibration?
Please and thank you.
Add to threecaster's Reputation
Rate the quality of this post and help threecaster reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
threecaster is offline   Reply With Quote
Old 02-27-2015, 04:10 PM   #2
bern
2004 ION-2 Sedan
Default Re: 2007 Vue radio receiver recalibration procedure
#06-08-44-030: Reduced Audio Volume Level When First Tuned to AM Radio or Loss of Volume After Signal Strength Reduction (Reprogram Radio) - (Sep 19, 2006)
Subject: Reduced Audio Volume Level When First Tuned to AM Radio or Loss of Volume After Signal Strength Reduction (Reprogram Radio)
Models: 2007 Chevrolet Cobalt, HHR
2007 Pontiac G5, Solstice
2007 Saturn ION, SKY, VUE
with US8 or US9 Radio
Condition
Some customers may comment on the following conditions:
•A period of reduced audio volume when first tuning to an AM radio station or when changing from another band (XM or FM) to AM.
•A loss of volume when the AM signal strength is reduced suddenly (as when driving into a garage, parking structure or under a bridge).
Cause
This radio includes a "soft mute" feature which is intended to mute the audio volume when a weak station is selected. The “soft mute" feature may not return the audio volume to the previous volume level as quickly as intended.
Correction
DO NOT replace the radio for this condition.
Notice: It is important to always use the correct utility file when programming a radio. Never use a utility file intended for another radio RPO in an attempt to resolve a concern. Using an incorrect file may result in permanent damage to the radio. To select the correct utility file, first determine the radio RPO (US8 or US9), and then determine if the vehicle is equipped with an audio amplifier (WBM, UZ6 or UQ3).
RPO from SPID Label
Speaker System
Includes WBM, UZ6 or UQ3
Enhanced Speakers with AMP
Does not include WBM, UZ6 or UQ3
Base Speakers without AMP
Reprogram the radio with the latest available calibrations (TIS 9.5 2006 or later) using the latest radio utility file. These calibrations will become available on TIS2Web on September 18, 2006. These calibrations will be available on the TIS 9.5 2006 CD and satellite broadcast later in September.
Refer to Radio Setup in SI for more information on reprogramming the radio.
After reprogramming, use the Tech 2® to confirm the complete 17-digit VIN is in the radio. If the VIN is not in the radio, manually enter the full 17-digit VIN using the Tech 2®.
Add to bern's Reputation
Adding a free AUX to the standard radio / cd receiver in Saturn SL2 (1997) maksym S-Series Mods 63 12-24-2015 06:10 AM
XM Radio Receiver ceh1354 2008 Vue 7 05-06-2008 05:13 AM
ECM recalibration? unstable23 Vue Tech 0 10-04-2004 12:06 PM
Satellite Radio Receiver ScooterRugger Ion General 0 08-04-2004 07:38 AM
2004 3.5 recalibration? VTECVue Vue General 5 03-19-2004 05:40 PM
