Old 02-14-2015, 02:49 PM   #1
RubenSw2
RubenSw2 is on a distinguished road
2001 SW2
Default 200k miles maintenance
Hello I just bought a 2001 sw2 Stickshift with 200k miles and with a new clutch installed. For Uber cheap now my question is what should I look for and what should I do to make sure it lasts an extra 200k miles I replaced the ignition switch cylinder and the coolant sensor it was owned by a mechanic who did regular oil changes with 5w30. The only problems it currently has is a small oil leak somewhere near the exhaust and it needs a new tps sensor which is causing it to putter (hesitate) with its idle. If anybody could give me tips I would gladly appreciate it.
Add to RubenSw2's Reputation
Rate the quality of this post and help RubenSw2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RubenSw2 is offline   Reply With Quote
Old 02-14-2015, 03:43 PM   #2
cdxhizors
cdxhizors has a spectacular aura aboutcdxhizors has a spectacular aura about
2002 L-Series 2.2L Sedan
Default Re: 200k miles maintenance
The oil leak by the exhaust..if youre talking about above the manifold that could be the valve cover gasket..Below might be the oil pan seal or crankshaft seal. I would do plugs, wires, flush the transmission, air filter just the normal stuff and let it be. That car has lived a long life as it is. It should last quite a while longer.
Add to cdxhizors's Reputation
Rate the quality of this post and help cdxhizors reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cdxhizors is offline   Reply With Quote
Old 02-14-2015, 06:50 PM   #3
Steve44
Steve44 will become famous soon enoughSteve44 will become famous soon enough
Steve44's Avatar
1999 SL1
Oil is the life blood of your engine. In a Saturn it is more important than any other Car. cdxhizors is likely right, your valve/Cam cover is probably leaking. Fix that and watch your Oil level like a hawk. Don't ever let the level get low, not even half a quart. If you keep your Saturn fed, full and clean, it will reward you with years of great service.
Welcome and Good luck!
Add to Steve44's Reputation
Rate the quality of this post and help Steve44 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
200K Mile Preventative Maintenance aerial_22 Vue Tech 7 10-17-2015 10:57 PM
200k Preventative Maintenance agroom Vue Tech 9 03-21-2014 02:45 PM
200K Miles Maintenance check-list darnell89 S-Series General 2 04-22-2008 01:26 PM
Today I hit 200k miles on my 92 SL2 turbobuick33 S-Series General 13 12-05-2005 02:16 AM
how to go 200k miles? 123SVT S-Series Mods 3 11-13-2002 06:28 PM
