Old 01-25-2015, 02:52 PM   #1
StrongFire
StrongFire is on a distinguished road
2001 SL2
Default 2001 SL2 Headlight Problem
The driver side headlight is not lighting most of the time. This only happens when I turn on the headlights. If I turn on the headlights and give the light a quick knock on the front of the lens, it lights and stays on for the duration of the drive. There are times (becoming more infrequent) when the headlight will turn on for a series of several headlight on/off cycles. The light does not flicker or turn off when I am driving. Also, I took apart the connector and cleaned it. This did not correct the problem. Any ideas where I should look or test for the source of the malfunction?
Add to StrongFire's Reputation
Rate the quality of this post and help StrongFire reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
StrongFire is offline   Reply With Quote
Old 01-25-2015, 03:15 PM   #2
Default Re: 2001 SL2 Headlight Problem
I would replace the bulb and hope that fixed it. If not you have a spare headlight bulb.
an update on the 2001 SC2 headlight water greencoupe02 S-Series General 6 09-22-2011 11:41 PM
2001-2002 SC2 headlight assembly removal greencoupe02 S-Series General 1 08-11-2006 08:59 AM
Looking for 2001 sc2 headlight assembly... etbardensc2 Classifieds 1 06-17-2005 06:03 AM
2001 SC2 Headlight. between5and7 S-Series General 3 12-09-2004 02:18 AM
