Old 01-21-2015, 02:42 AM   #1
Swebner
Swebner has a spectacular aura aboutSwebner has a spectacular aura about
2004 VUE 3.5L
Wrench Exhaust connection came apart
Hello everyone,
I noticed the other morning that my car sounded like I had one of those "fart can" mufflers on it.
I looked underneath and saw the exhaust pipe connection between the muffler pipe section and catylitic converter pipe section had broken apart.
I later found the broken bolt with the nut still on it on the garage floor.
I'm guessing that driving over some of the snow plough "glaciers" outside of my house bumped it hard enough to crack it and that starting it up the next morning bounced the broken fastener out.
Everything's still hanging on and the other fastener/nut at the connection are still in tact. The bolt heads look like they're welded on and probably need to be drilled out to replace the fasteners.
I would of course replace both fasteners and replace the gasket for the connection.
Has anyone else had to deal with these welded/riveted fastener heads or have any other tips for repairing this?
The Lord works in mysterious Automotive Problems.
Add to Swebner's Reputation
Rate the quality of this post and help Swebner reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Swebner is offline   Reply With Quote
Old 03-02-2015, 10:01 AM   #2
Swebner
2004 VUE 3.5L
Default Re: Exhaust connection came apart
The problem
The repair
This is the exhaust flange following the Y-Pipe.
Started by drilling a 1/4" pilot hole through the head of the stud. Increased that to a 3/8ths".
Used some vinegar water on the existing fastener and wire brushed it.
Breaker bar got it loose after some convincing. I didn't want to crank too hard and put too much tension on the Y-Pipe.
Scraped away the old blown out gasket and put a fresh one on.
Inserted new fastener and tightened it up nice.
No more fart can!
Old 03-02-2015, 10:25 AM   #3
SL19302
SL19302's Avatar
2002 SL1
Be happy you were actually able to do that, Most exhaust flanges are rotted away so bad an exhaust shop has to weld a new one in.
CHECK YOUR OIL!
Add to SL19302's Reputation
Old 03-02-2015, 11:13 AM   #4
Swebner
2004 VUE 3.5L
Yea it does look pretty good underneath. Not bad considering I'm in a salt-using city during the winter.
Old 03-02-2015, 12:00 PM   #5
billysvue
I wonder how well Barbecue paint or "RUstoleumHIgh HEat" paint would protect all those exhaust parts from corrosion in the SAltBElt...
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Add to billysvue's Reputation
Old 03-21-2015, 06:29 PM   #6
saturnsctwo
I got a slight exhaust leak there & my flanges are rusted away. I got to get them welded as, but yours look good like mine did years ago...
Old 04-05-2015, 05:26 PM   #7
padlock1978
padlock1978 has a spectacular aura aboutpadlock1978 has a spectacular aura about
we are getting ready to replace the whole exhaust on our 03 vue. Should be fun,lol
My Rides
03 Saturn Vue Canary Yellow
99 F150. 5.4 Running Strong
89 Mustang 351W pushing over 400HP
Add to padlock1978's Reputation
Rate the quality of this post and help padlock1978 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
padlock1978 is offline   Reply With Quote
See any connection ?????? railguy7 General Saturn Discussion 9 02-27-2009 10:09 AM
TPS connection whitey99 S-Series Tech 4 09-26-2008 10:31 PM
is there any connection between .... saturn_guy S-Series General 7 08-10-2005 08:43 PM
Gm Cvt Doa- Car Connection 7/27/04 lewis2 Ion General 30 08-01-2004 07:22 PM
Help !! Is there a connection... ladybugg99 S-Series Tech 8 04-25-2003 02:13 PM
