Old 01-13-2015, 05:48 PM   #1
affa22
affa22 is on a distinguished road
Default Engine Stutter Between 3500-4000 rpm
My Astra has been doing this really annoying shudder between 3500-4000rpm... While merging on the highway or at WOT (while the engine is under load) it goes from no power, to all the power, back to no power and continues back and forth until I'm over 4000rpm and then it smooths out. I'm not throwing any codes but I thought it might be the timing actuator valves and/or the MAF so I replaced both of them and cleaned the throttle body and it didn't help. My next thought is that it could be something to do with the intake runners on the manifold. Has anyone else had any problems similar to this?
Any help is appreciated!
Add to affa22's Reputation
Rate the quality of this post and help affa22 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
affa22 is offline   Reply With Quote
Old 01-13-2015, 07:27 PM   #2
ReGZ_93
ReGZ_93 is on a distinguished road
2008 Astra XE
Default Re: Engine Stutter Between 3500-4000 rpm
When was the last time you changed your spark plugs? You could be seeing the early signs of a bad coilpack.
Add to ReGZ_93's Reputation
Rate the quality of this post and help ReGZ_93 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ReGZ_93 is offline   Reply With Quote
Old 01-13-2015, 10:35 PM   #3
affa22
Thanks for your reply,
I don't know the exact km but they are E3's and are way under their "warrantied" time.. for whatever that's worth.
None the less I will check them in the upcoming days.
Would a coil pack only manifest itself before 4k rpm? Is there a way to check to see if they are functioning properly?
v6 engine will not rev over 4000 rpm 03lseries L-Series Tech 9 09-09-2011 01:23 AM
Engine limited to 4000 rpm groingo S-Series General 11 04-28-2009 11:42 AM
Weak Engine above 4000 RPM IFlyGC S-Series General 1 04-12-2005 06:59 PM
engine surges at 4000 RPM lbowtie S-Series Tech 7 02-28-2005 11:35 AM
'92 SC engine will not rev past 4000 rpm speedinc Miscellaneous Tech 11 05-19-2003 09:45 AM
