Old 12-31-2014, 10:49 PM   #1
vikasevan
vikasevan has a spectacular aura aboutvikasevan has a spectacular aura about
vikasevan's Avatar
2001 SL2
2004 VUE 3.5L
Default 2001 Saturn SL2 - sunroof compatibility?
I have 2001 saturn sl2
and I replaced sunroof frame from 1996 saturn sl from a junk yard
and motor I don't remember but I believe it motor was from year after 1996 car.
Now after putting frame and motor (they are from two separate saturns)
it does not move ...it engages but very slight movement in the rails...but neither vent position or open postion
1. could it be incompatible motor and frame problem?
2. could be some jamming in rail passages so even though motor is trying ...things cant move because of some sort of blockage?
3. Do I need to reset motor? if yes what is the procedure?
Add to vikasevan's Reputation
Rate the quality of this post and help vikasevan reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
vikasevan is offline   Reply With Quote
Old 01-01-2015, 08:35 PM   #2
ShawnV
ShawnV is a jewel in the roughShawnV is a jewel in the roughShawnV is a jewel in the roughShawnV is a jewel in the rough
ShawnV's Avatar
Default Re: 2001 Saturn SL2 - sunroof compatibility?
Did you test the sunroof module before you installed it? I like to test them when they're still in the car with a cordless tool battery. I've never found one that worked and I would guess your module has broken parts. These sunroof parts are garbage and do not last. Your best bet is to close it and pull the sunroof fuse and consider it a moonroof.
Shawn
Add to ShawnV's Reputation
Rate the quality of this post and help ShawnV reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ShawnV is offline   Reply With Quote
Old 01-01-2015, 09:05 PM   #3
vikasevan
vikasevan's Avatar
2001 SL2
2004 VUE 3.5L
Question Re: 2001 Saturn SL2 - sunroof compatibility?
so when ever you have found used ones ....none of them were good?
I will check with cordless battery.
I understand you said parts might be broken...but do you think battery needs to reset or something?
also do you think battery could be incompatible with module?
2001 Saturn SL2 - sunroof does not work at all vikasevan S-Series Tech 3 12-09-2014 03:19 PM
SL - SC Sunroof Compatibility t0030tr S-Series General 11 02-13-2012 05:00 PM
1999 SL engine swap compatibility with 2001 J302 S-Series Tech 12 07-19-2010 02:32 PM
2001 saturn sl2 rear vent glass compatibility mambo S-Series General 3 12-31-2009 09:26 PM
Sunroof size/compatibility question Col.FUBAR S-Series Tech 8 08-01-2009 01:37 PM
