Old 12-25-2014, 05:44 PM   #1
vikasevan
vikasevan has a spectacular aura aboutvikasevan has a spectacular aura about
vikasevan's Avatar
2001 SL2
2004 VUE 3.5L
Question What is wrong with sunroof?
2001 Saturn SL2
Sunroof does not work at all...no movement nothing ...where should I start?
I checked fuse ..15 A fuse is ok ...checked relay for window that is ok as well.
This fuse and relay are on passenger side close to seat ..
should I check under the hood fuse box for any thing
what else should I check?
Previous owner broke that light connector so I cant try to turn on those lights and when I press that middle switch no movement at all.
is there any motor I should check?
Add to vikasevan's Reputation
Rate the quality of this post and help vikasevan reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
vikasevan is offline   Reply With Quote
Old 12-25-2014, 09:33 PM   #2
vikasevan
vikasevan's Avatar
2001 SL2
2004 VUE 3.5L
Question Re: What is wrong with sunroof?
Ok I replaced the switch and now it responds to close/vent/open command but it makes noise, with a very little movement.
It does make a little movement towards back of the sunroof towards driver side corner when I press vent/open button.....but than make noise...
Now what should I trouble shoot?
It could be faulty motor?
or broken gear?
or broken plastic arms?
dirty arms?
what exactly I should start with? is it possible I can do anything without removing headliner?
Old 12-26-2014, 10:01 AM   #3
blue92
blue92 will become famous soon enoughblue92 will become famous soon enough
1992 SL1
Default Re: What is wrong with sunroof?
http://www.sunroofdoctor.com/9602saturn.htm
92 SL1 original owner
94 SL2 Homecoming
98 SC2 White Hot
02 SC2
Add to blue92's Reputation
Rate the quality of this post and help blue92 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
blue92 is offline   Reply With Quote
Sunroof Doctor Replacement...what did I do wrong? rx7 se S-Series General 22 06-19-2012 03:46 AM
(Saturn of Glen Burnie - saturnparts.net vs Sunroof Dr.) sunroof part question. droveavolvoonce S-Series Tech 10 10-27-2010 10:23 PM
08 Vue Sunroof wired wrong? whort 2008 Vue 3 06-03-2010 09:02 PM
Saturn messed up idles wrong, sounds wrong Pandoraisgod S-Series General 7 01-24-2005 02:25 AM
