Old 12-18-2014, 10:09 PM   #1
zmarrott
zmarrott is on a distinguished road
Default '95 SC2 weak power steering
So recently my beast of a car decided to add one more thing to the list of needed repairs. im not sure the cause but my power steering has become all but useless. i dont really notice it much while the car is moving, but if im stopped it feels like i have no assistance from the pump. i can hear it straining trying to help, but to minimal effect. the fluid level in the reservior is fine and i dont see any fluids dripping out the bottom. what could cause this?
Add to zmarrott's Reputation
Rate the quality of this post and help zmarrott reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
zmarrott is offline   Reply With Quote
Old 12-18-2014, 11:11 PM   #2
Highmile
Highmile's Avatar
Default Re: '95 SC2 weak power steering
Check the belt and tensioner first although I would think you'd hear it if it was slipping.
Sounds like the pressure relief valve may be stuck or the valving in the power rack itself could be bad.
Good luck
Highmile
'95 SL1 559k and counting
Add to Highmile's Reputation
Old 12-19-2014, 12:04 AM   #3
zmarrott
tensioner is brand new. had to replace that a few weeks ago due to it squeaking on the alternator. where might i find said valves to check them?
Old 12-19-2014, 03:27 AM   #4
wi111y
wi111y is on a distinguished road
1995 SL
1995 SW2
There should be a solenoid attached to the power steering pump where the high pressure hose goes in at the bottom rear. idk how you would go about checking it, and it's sort of a pain to remove just to test.
'95 SL 5 Speed 220k - DD
'95 SW2 5 Speed 230k - Gone!
'95 Camaro Z28 - Project
'00 Tahoe Z71 - Truck stuff
Add to wi111y's Reputation
Rate the quality of this post and help wi111y reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
wi111y is offline   Reply With Quote
Old 12-19-2014, 10:42 AM   #5
Search threads explaining the EVO sensor on the pwr steering pump. It may be faulty. The sensor varies pump pressure so slow speed parking gives the most steering assist and reduces it as speed increases, less assist at highway speeds.
2006 Ion - Dealer did power steering recall service ... still losing power steering! lbi2000 Ion General 2 08-11-2014 10:39 AM
Weak Power Locks. Actuators or...? 2kSL1 S-Series General 3 09-22-2012 01:00 AM
2002 SL1 -- starting and weak power c-rizzle S-Series General 3 07-15-2011 12:12 PM
A solution for the weak Astra horse-power! Saturn#5 Astra General 26 10-26-2009 12:09 AM
diagnosing weak power s-series MacExperts S-Series Tech 2 10-06-2006 06:46 PM
