Old 12-13-2014, 04:20 PM   #1
Hockey
Hockey is on a distinguished road
1996 SL1
Default How do I safely convert to LED headlights?
I have a 96 SL2 Base Auto. I feel safe driving in winding backwood roads, but would prefer more visibility than what my headlights currently offer. I have no idea where to start. I do know that the state I live in requires all aftermarket lighting equipment be DOT or SAE approved. I'm not afraid to work on the car myself, but not comfortable at all to touch the CPU.
Grandma's '96 SL1 140k
Add to Hockey's Reputation
Rate the quality of this post and help Hockey reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Hockey is offline   Reply With Quote
Old 12-13-2014, 04:42 PM   #2
AlexofNazareth
AlexofNazareth will become famous soon enough
AlexofNazareth's Avatar
2002 SL1
Default Re: How do I safely convert to LED headlights?
1. Forget about LEDs
2. Look for Phillips HIR bulbs for the car.
http://store.candlepower.com/hirlighting.html
3. Headlights do not affect the ECU/PCM
'02 SL1.414213562^2, Deebs ftw
Add to AlexofNazareth's Reputation
Rate the quality of this post and help AlexofNazareth reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
AlexofNazareth is offline   Reply With Quote
Old 12-13-2014, 05:35 PM   #3
billysvue
here
https://www.google.com/webhp?sourcei...iving%20lights
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Add to billysvue's Reputation
Old 12-13-2014, 06:35 PM   #4
mattwithcats
mattwithcats has a spectacular aura aboutmattwithcats has a spectacular aura about
Fog lights...
Switch, two lights with bracket, some fuse box parts, and 20 minutes work...
Parts can be found in a junkyard...
A 9011 bulb can be used instead of the 9005/9006 headlight bulb, with some modification to the base.
Or Silverstar Ultra's...
Pennzoil Ultra Platinum 5W-30, NAPA 41516...
NGK BKR6E-11 spark plugs
Old 12-13-2014, 06:39 PM   #5
AlexofNazareth
2002 SL1
Originally Posted by mattwithcats View Post
Fog lights...
Yes, because fog lights help so much with seeing far ahead of the vehicle. A
Old 01-01-2015, 03:09 PM   #6
jeff5may32
jeff5may32 is on a distinguished road
Very helpful. Not.
You basically have two options:
A: Replace your headlights with something brighter. Too bright is not DOT compliant. At least not on-road.
B: Add driving lights (basically the same thing as fog lights but not yellow). Aiming the lights too high (where they would blind oncoming traffic) or adding too bright of lights is not DOT compliant.
Add to jeff5may32's Reputation
Rate the quality of this post and help jeff5may32 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jeff5may32 is offline   Reply With Quote
Old 01-01-2015, 03:50 PM   #7
ninetynineSC2
ninetynineSC2 has a spectacular aura aboutninetynineSC2 has a spectacular aura aboutninetynineSC2 has a spectacular aura about
ninetynineSC2's Avatar
Well, my stock ones not only help light the side of the road, they also light at least a foot or two further than the lows on their own.
Current:
1999 SC2, 186,XXX
Past:
1989 Mustang LX, Unknown mileage(JY engine in it when I got it)
Add to ninetynineSC2's Reputation
Rate the quality of this post and help ninetynineSC2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ninetynineSC2 is offline   Reply With Quote
Is There a Way to Safely Clean My Headliner CrunkedRL Vue Red Line 6 08-10-2009 02:40 PM
How-to: Seperation of Outer Tie Rod End from Spindle (safely) rc1488 S-Series General 30 01-27-2008 11:15 AM
Can I safely remove the EGR w/o the computer going haywire mikes 1994 z28 S-Series Mods 5 05-04-2006 04:52 PM
Remember to drive Safely my99sl1 General Saturn Discussion 0 12-23-2004 04:57 PM
How can I remove wax safely. DualCamCoupe Miscellaneous Tech 4 05-20-2003 11:40 AM
