Old 12-08-2014, 08:52 AM   #1
new vue-er
new vue-er is on a distinguished road
Default 2004 V6 AWD Vue Start Up problem
For the past 2 months I've had a had issues starting up my Vue. When I turn the key, the power goes on, but will not always start up. When it happens, the engine doesn't crank or make a sound. I'll take the key out and try it again- sometimes it works, other times I'll try again by moving the steering wheel or jiggling the key.
It seemed to do better after I replaced the ignition & key (from the recall notice). I also had the starter replaced in the last 2 weeks. (warranty), but am still having problems.
I'm at wits end! Any ideas what could be the cause and fix?
Thanks in advance. This board is a great resource.
Add to new vue-er's Reputation
Rate the quality of this post and help new vue-er reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
new vue-er is offline   Reply With Quote
Old 12-08-2014, 08:55 AM   #2
billysvue
Default Re: 2004 V6 AWD Vue Start Up problem
clean your battery posts and clamps, then reinstall.
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Add to billysvue's Reputation
Old 12-08-2014, 09:27 AM   #3
new vue-er
Thanks for the quick response. I forgot to mention that I replaced the battery when I first had problems - I was going to do it regardless. I'll see what happens when I replace the cables.
Hopefully, that's the cause.
Old 12-08-2014, 10:24 AM   #4
Mileage? Next would be a worn out starter.
Old 12-08-2014, 10:46 AM   #5
far2grumpy
far2grumpy's Avatar
The transmission PARK/NEUTAL safety switch might be slightly out of adjustment.
Try moving gear selector in PARK while turning key to START - you could also place selector to N while trying to start.
The 3.5 Vue's also have a start relay - not in under-hood fuse block (UHFB) but in wiring harness next to UHFB. I can send photo of relay location if messing with gear shift does not help.
Old 12-08-2014, 12:06 PM   #6
new vue-er
178,000 K mileage. I replaced the original starter 2 years ago, and then put it another starter (under warranty) approx. 600 miles ago when replacing the key and ignition solution didn't work.
Old 12-08-2014, 01:12 PM   #7
new vue-er
I appreciate your response and suggestions. It's funny, because sometimes I'll move the gear shifter and/or the steering wheel and it starts. Other times nothing happens.
I'll have my mechanic look at the Start Relay next week when I bring the Vue in for it's oil change & service. I know it's coincidental but ever since I put in a new radio 3 months ago, I've seem to have electrical issues (rear hatch latch recently shorted out).
Thanks again for your help.
Old 12-08-2014, 04:59 PM   #8
There seems to a rash of premature replacement starter failures. 600 miles on a replacement is poor quality and fortunately covered by a warranty. The problem is whether or not this second replacement is suffering the same lack of quality............
Old 12-10-2014, 03:13 PM   #9
far2grumpy
far2grumpy's Avatar
I've attached two thumbnails which might help mechanic understand the starting circuit and locate the starter relay.
The ignition switch box is attached to rear of the ignition lock cylinder and I imagine they simply disconnected your existing switch from old cylinder and moved to new one. This means - of course - if the old switch had an intermittent connection in start circuit it'd still be there.
Since your IPC (instrument panel cluster) always indicates power is on when key is turned ON we could assume wiring from battery - to IGN 30A fuse - through connector C200 - to the ignition switch box is good.
So, if Vue was in my driveway I'd remove the STARTER RELAY and with key OFF and transmission in PARK or NEUTRAL - would temporarily touch a jumper wire from battery positive terminal to terminal 30 on the start relay socket. A good starter will spin the engine each time connection is made.
If starter operates - re-install relay and work back to the ignition switch box (rear of lock cylinder). I'd disconnect connector from the box and temporarily touch 12 volt jumper to pin C (yellow wire) of the vehicle wiring harness. If starter turns after each touch it basically confirms the starter switch is bad.
These switches are not difficult to replace (I've done one ) and web-prices are in range of $40 to $60 USD (RockAuto).
Old 02-18-2015, 07:55 PM   #10
new vue-er
Just wanted to give you an update. Approximately a week after my mechanic replaced the starter relay, the problem arose once again. The first time it happened, I shifted from Park down to Nuetral and back to Park. It started right up. The next time it happened, I turned the steering wheel left when it wouldn't start, and then it cranked up. So, I am at a loss for what could be causing this.
Any Ideas??
Old 09-10-2015, 09:06 AM   #11
bryanmcavoy
bryanmcavoy is on a distinguished road
Was wondering if you ever found out what was causing this? I also have a 2004 Vue, (Manual Trans) I experience no starts at times just like you, wait 2 or 3 minutes then it starts, Prior to the recall for the ignition switch replacement I never had this issue, 108 K in mileage -
Add to bryanmcavoy's Reputation
Rate the quality of this post and help bryanmcavoy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bryanmcavoy is offline   Reply With Quote
Old 09-13-2015, 07:42 PM   #12
new vue-er
It's funny, but I haven't had any recurrences since the spring. Personally, I think it was the Park/Neutral safety switch ( as Far2grumpy mentioned). Every time that I had the problem, if I moved the shifter from out of park and back it seemed to work.
Not sure why I haven't had problems in a while, but I'm not complaining.
Good luck to you.
2004 Vue 3.5L Won't Start AHidell Vue Tech 6 12-01-2014 05:44 PM
Won't start 2004 ion nickpratt2010 Ion Tech 8 09-04-2013 04:04 PM
2004 Vue 2.2L won't start mjvandine Vue General 3 03-26-2013 11:35 AM
2004 Ion-3 Won't Start truck1985 Ion Tech 26 01-12-2013 08:00 AM
2004 Ion 3 won't start truck1985 Ion General 2 01-30-2012 11:55 AM
