Old 12-07-2014, 10:35 PM   #1
vikasevan
vikasevan has a spectacular aura aboutvikasevan has a spectacular aura about
vikasevan's Avatar
2001 SL2
2004 VUE 3.5L
Default 2001 Saturn SL2 - sunroof does not work at all
Sunroof does not work at all...no movement nothing ...where should I start?
I checked fuse ...fuse is ok ...what else should I check?
Where is relay?
is there any motor I should check?
Add to vikasevan's Reputation
Rate the quality of this post and help vikasevan reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
vikasevan is offline   Reply With Quote
Old 12-08-2014, 08:50 AM   #2
Default Re: 2001 Saturn SL2 - sunroof does not work at all
If it's like 1st and 2nd gens you can take the map lights out and see the connector to the motor as well as replace it if needed. Use a DMM to check for power (you'll have to reconnect the map lights with the switch to test). If it's not getting power to the motor you'll have to diagnose farther up stream, such as the switch in the map lights.
Probably best to start by looking for the typical sunroof fix however....check for silicone or some other sealer around the glass on the roof.
Old 12-08-2014, 10:00 AM   #3
Upstate Saturn
Upstate Saturn has a spectacular aura aboutUpstate Saturn has a spectacular aura aboutUpstate Saturn has a spectacular aura about
Upstate Saturn's Avatar
2001 SL2
Mine got stuck open *once*, and after I jiggled the switch and got it to close, I've never opened it again! I may try the silicone solution as one job on my to-do list is to unplug the sunroof drains where they exit under the rear quarter panels, wouldn't mind not ever having to do it again....
2001 SL2 manual - original owner - remanufactured engine at 228k miles, December 2015
1992 SL1 - bought used in '93, totaled in '00 at 170k miles, drove it cross-country a lot!
Add to Upstate Saturn's Reputation
Rate the quality of this post and help Upstate Saturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Upstate Saturn is offline   Reply With Quote
Old 12-09-2014, 03:19 PM   #4
vikasevan
vikasevan's Avatar
2001 SL2
2004 VUE 3.5L
Well, when I push switch ...nothing no movement...when I press button next to switch ..no lights come on...does it say something?
How much work to replace my roof panel with one without a sunroof? HankHill S-Series Tech 10 09-17-2013 04:16 PM
(Saturn of Glen Burnie - saturnparts.net vs Sunroof Dr.) sunroof part question. droveavolvoonce S-Series Tech 10 10-27-2010 10:23 PM
'95 SC2, Sunroof doesn't work SaturnNJeep S-Series Tech 12 08-11-2010 05:59 AM
Sealing sunroof closed...Will this work? 1997_SL2_90K S-Series Tech 7 09-24-2007 03:34 AM
Sunroof won't work and leaking water GDP-89SC2 S-Series Tech 2 01-24-2007 06:47 PM
