Old 12-07-2014, 10:02 PM   #1
vikasevan
vikasevan has a spectacular aura aboutvikasevan has a spectacular aura about
vikasevan's Avatar
2001 SL2
2004 VUE 3.5L
Question We have two trouble code service engine light on
Hi,
We have 2001 Saturn SL2 with 220k miles.
I have two trouble codes P0037 and P0410
I believe p0037 means replace downstream oxygen sensor(after cat)
and p0410 means something about air pump correct?
How should I start trouble shooting please advice.
Add to vikasevan's Reputation
Rate the quality of this post and help vikasevan reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
vikasevan is offline   Reply With Quote
Old 12-08-2014, 12:03 AM   #2
billr
Default Re: We have two trouble code service engine light on
Trouble codes rarely mean "replace this-or-that", they mean to do further diagnosis in a certain system. Don't just throw parts at it, unless cost is no issue, let's start with that advice.
Edit: check for a blown fuse in the two fuse/relay boxes. You may get lucky and find the same fuse feeds both systems. Somebody else can probably post a picture of specifically which fuse feeds the O2 sensor heater.
Add to billr's Reputation
Old 12-08-2014, 03:56 AM   #3
You can ignore the P0037 O2 sensor temporarily until the P0410 is repaired. Unless the engine is acting erratically, the rear O2 sensor is used to monitor the catalytic converter's efficiency and reports it for emissions purposes whether or not your state requires emissions inspection.
Search for threads about the secondary air injection system.
Old 12-08-2014, 05:06 AM   #4
Signmaster
Signmaster is a name known to allSignmaster is a name known to allSignmaster is a name known to allSignmaster is a name known to allSignmaster is a name known to allSignmaster is a name known to all
Probably one of the best videos for finding the P0410 issue, courtesy of a forum member....
Richpins P0410 troubleshooting video
Old 12-09-2014, 03:17 PM   #5
vikasevan
vikasevan's Avatar
2001 SL2
2004 VUE 3.5L
Question Re: We have two trouble code service engine light on
But do you think faulty downstream O2 sensor could cause P0410 code (secondary air system code)
Old 12-09-2014, 03:29 PM   #6
In one word, no.
Old 12-09-2014, 03:32 PM   #7
vikasevan
vikasevan's Avatar
2001 SL2
2004 VUE 3.5L
Ok how about otherwise...
faulty secondary air system could case fault in downstream O2 sensor?
Old 12-09-2014, 03:44 PM   #8
No one can tell you one way or the other. You may be troubleshooting two separate problems. Since the O2 error code is downstream and temporarily of less importance, troubleshooting the secondary air system is, in my opinion, a priority. It's your choice to choose which problem to work on.
Old 12-10-2014, 02:17 PM   #9
vikasevan
vikasevan's Avatar
2001 SL2
2004 VUE 3.5L
Just fyi ...emis fuse was blown so solenoid did not have any voltage.
Old 12-10-2014, 02:42 PM   #10
And................?
Old 12-10-2014, 02:54 PM   #11
vikasevan
vikasevan's Avatar
2001 SL2
2004 VUE 3.5L
Well... I changed fuse and clear code with scan tool... Will know if code comes back
Service Engine light but no code Joshtheclockman S-Series Tech 12 10-10-2011 01:47 PM
Trouble Code and Service Engine Light Big__Daddy General Saturn Discussion 1 11-10-2005 10:15 PM
Trouble Code and Service Engine Light Big__Daddy S-Series General 7 11-07-2005 07:05 PM
Trouble Code 49 on Service Engine Soon Light 93sl1 S-Series Tech 10 11-19-2002 10:19 PM
Check Engine Light - Invalid Trouble Code AxeMan S-Series Tech 24 10-17-2002 06:29 AM
