Old 12-05-2014, 02:43 PM   #1
Rhyno86
Rhyno86 will become famous soon enough
Dizzy Subwoofer kill switch?
Hello all! 2003 Ion-2 here.
I installed a single 12" subwoofer and amplifier in the trunk. I connected the power to the amplifier directly to the battery in the wheel well with 6ga wire and an inline fuse.
The problem I am having is that the amplifier seems to be draining power even though the engine is off. I have the remote wire from the head unit to the amplifier connected correctly, as the amplifier turns on when I start the car and turns off when I turn the car off, but it is still draining the battery somehow while off.
I first noticed the problem when my car sat for a week while I was on vacation, and came home to a dead battery. I tried several different scenarios and finally realized that I had no problems with the battery draining at all after I had completely disconnected the power to the amp.
My main question is:
Is there a switch or relay that I can install to completely kill the power to the amp? I know I could install a switch inline with the power wire, but I don't want to run the 6ga wire all the way to the front and all the way back again. I'd rather run a single, smaller gauge 2-conductor wire (like an 18/2) to the front connected to a switch that would control a relay in the back capable of handling the 6ga wire. If I could do that, what kind of relay would I need?
Add to Rhyno86's Reputation
Rate the quality of this post and help Rhyno86 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Rhyno86 is offline   Reply With Quote
Old 12-05-2014, 05:47 PM   #2
caveeagle
caveeagle is a glorious beacon of lightcaveeagle is a glorious beacon of lightcaveeagle is a glorious beacon of lightcaveeagle is a glorious beacon of lightcaveeagle is a glorious beacon of light
caveeagle's Avatar
Default Re: Subwoofer kill switch?
Here is the best way to mount your sub woofer 'kill' switch.
Mark
'05 Vue, '02SL1, '01SC2a, '01SC2b, '99SL1 :::::> '04 SVT Cobra, '67 Mustang Vert.
Add to caveeagle's Reputation
Rate the quality of this post and help caveeagle reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
caveeagle is offline   Reply With Quote
Old 12-05-2014, 07:55 PM   #3
ruley73
ruley73's Avatar
2007 ION-2 Quad Coupe
This is what the remote wire should already be doing. The amp doesn't turn on (and doesn't draw any power) when no power is being fed to the remote wire. Power from the remote wire causes a relay inside the amp to close the circuit for the amp's main power source.
Some amps have an auto on/off feature that can be utilized in lieu of a separate remote wire when speaker/high level inputs are used. The amp turns on automatically when a speaker signal is received and automatically shuts off a few minutes after no signal is received.
In either case, as long as you are seeing the amp turn off when the key is turned off, the amp cannot be the source of your battery drain.
2007 Chevy Equinox LT 183K miles
Add to ruley73's Reputation
Old 12-05-2014, 11:29 PM   #4
Rhyno86
I think there may be a grounding issue within the amp, so I do believe it is drawing small amounts of power even though the power light on the amp is off. I can't afford a new amp at this time, so I'm really looking for a solution with a relay.
Old 12-06-2014, 12:09 AM   #5
cyoder4400
cyoder4400 is on a distinguished road
cyoder4400's Avatar
It would be really crude but go to Home Depot or the likes and get a switch that can handle that amperage and splice it into your power line for the amp. Keep it somewhere near the front seat and just turn it off when you leave. Or you could remove the fuse out of the line.
'93 Saturn SL2 1.9L DOHC 4-speed automatic (The first car) 192K
'02 Saturn SL 1.9L SOHC 5-speed manual (The pizza delivery car) 171k
Keep oil in it and it will never die!!!
Add to cyoder4400's Reputation
Rate the quality of this post and help cyoder4400 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cyoder4400 is offline   Reply With Quote
Old 12-06-2014, 08:51 AM   #6
ruley73
ruley73's Avatar
What makes you think it is a grounding issue? If the amp is drawing power when it's turned off, there is another problem not related to the ground connection. Any grounding issue you may have would either cause a short circuit which would be blowing fuses or an open circuit which basically means it is disconnected from the battery. The only way to confirm the amp is drawing power is to connect an ammeter around the positive or negative power cable going to the amp.
Old 12-06-2014, 09:29 AM   #7
caveeagle
caveeagle's Avatar
Its really not that unusual for electronics to draw power even when they are switched off.
What the op really wants to do is install a relay to totally cut power to the amp when not in use.
There are a couple ways to do this and there are different types of relays that would work for this.
You could put a small switch on the console to send switched 'signal' power to your relay, that would close the circuit to your direct 12v battery feed.
You could also tap the relay 'signal' feed into a 'key-on' 12v source so that your amp get direct 12v only when the ignition key is on.
Or, You could do both, tapping the signal switch into a keyed 12v source, so that you could turn amp power on/off, but only when the ign is in the on position.
One other option is that you just draw the relay signal wire from the stereo head unit. I suspect, that if you dig into the manuals, thats probably how it should be done. This way turning on the head unit will trip the relay and supply full battery voltage to the amp.
I would find a simple relay that can handle the amperage your aplifier draws, and find one with a matching harness. Just make sure you make clean connections with plenti of insulation. Install the appropriate inline fuse, so you don't burn up your car.
...And please don't get next to me in traffic and blast your bass so loud it makes my teeth rattle!
Mark
Old 12-06-2014, 11:43 AM   #8
ruley73
ruley73's Avatar
I know it's normal for some electronics to draw power when turned off, but a car amplifier is not one of them unless you have a really fancy one or there's something wrong with it. They don't have any memory that is required to keep settings like most other things on the car like the BCM, ECM/PCM, radio, and OnStar. Putting a relay in the main power circuit would be a good idea if in fact it is the amp drawing power when turned off. I just don't want to see the OP go through all that work unless they are absolutely 100% sure the amp is the problem.
What make/model is the amp?
How old is the battery?
Old 12-08-2014, 09:11 AM   #9
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
had the same issue in my GF's civic with theamp killing the car. it was an issue with the amp, and it was brand new.
all we did, if the car was going to be parked for a long time, then wed pull the fuse under the hood. the gound and everything were properly installed
Somehow, the amp would keep itself powered on at all times.
this amp was a planet audio 1800w 5ch
adding a switch inline on the remote power on wire will help to turn it on and off, being the amp works properly.
Since in your case, the amp may stay powered on, even when the radio or car is turned off, which indicates something wrong with the amp possibly
i would deffinatly get the battery tested just to be sure, and make sure your audio wires and remote wire are away from the power wire.
run them along the driver side of the car since the main power feed from the battery runs along the passenger side.
03 ion-2 Sedan 5sp
♕KCCO
Add to kevin.st56's Reputation
Rate the quality of this post and help kevin.st56 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Alarm kill switch for '99 SL2? melissa.bluth13 S-Series Tech 1 03-31-2010 08:06 PM
Ignition kill switch MikeNW S-Series General 8 08-11-2009 03:36 PM
Kill Switch ? Krusher S-Series Tech 11 08-22-2008 09:03 PM
kill switch kayaksonvue Vue General 7 07-16-2004 11:31 PM
Kill switch plumsl2 General Saturn Discussion 6 03-07-2004 03:38 PM
