Old 11-24-2014, 07:37 PM   #1
ChocolateSouce
ChocolateSouce is on a distinguished road
Default 2005 Saturn Ion troubles..
It all started a couple months ago; my Ion had all the sudden started dropping RPM's whilst in a drive-thru. It would drop to approx. 500 rpm, the lights and dashboard would dim, then it would jump back up to it's average idle. This continued for some time until it got worse this beginning of winter. It would do the same thing as before, but now the RPM's would drop too low and the car would stall. I ran some codes off the OBDII and I got P0300 (Random Cylinder Misfire) and another code that I can't recall but concerned the MAP sensor, which I have now replaced. The car was sitting a while waiting for the part and also resides in Canada meaning it sat in the cold. With the sensor replaced, and the battery charged, we finally got it to start. I drove maybe half a block and then the car just shut off completely. I tried turning it back on, but the dash would rapidly click and the engine wouldn't even turn over. I have guessed that maybe I need to reset the ECU but am running out of ideas at this point. Somebody has had to have had this problem and I am looking for any ideas! Thanks.
Add to ChocolateSouce's Reputation
Rate the quality of this post and help ChocolateSouce reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ChocolateSouce is offline   Reply With Quote
Old 11-24-2014, 09:56 PM   #2
2006 ion2
2007 ION-2 Sedan
Default Re: 2005 Saturn Ion troubles..
Fix the misfire. Hopefully you didn't ruin the engine. Search on here, this is a common issue
2007 Saturn Ion 2
2003 Chevrolet venture lt
Add to 2006 ion2's Reputation
Saturn sl1 idle troubles ooohhh yyyyaaaa S-Series Tech 4 08-14-2013 04:34 AM
ecm tuning 2005 vue v6 ja35a3 http://www.drivewire.com/vehicle/2005-saturn-vue/ecu-up teamsheetz Vue General 2 10-28-2012 03:33 PM
2003 Saturn Vue Troubles kristen27 Vue General 5 06-29-2009 01:11 PM
New to Saturn SL1 - HELP! Troubles eightofus4him S-Series General 2 01-09-2007 11:18 AM
Troubles with Saturn SL1 95 Lizzy S-Series Tech 7 10-21-2005 04:07 PM
