Old 11-24-2014, 02:57 PM   #1
willada1
willada1 is on a distinguished road
Default Leaking coolant
So my engine froze because i kept putting off replacing my radiator. so i had to replace the water pump and radiator. but after doing all of this, I added water to test to see if there were any leaks and water started pouring out from what looks like behind the thermostat housing. so my question is what could be the problem/ is there a way to fix it? this is my only car and im struggling without it so any help would be much appreciated.
Thank You,
Dakota
Add to willada1's Reputation
Rate the quality of this post and help willada1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
willada1 is offline   Reply With Quote
Old 11-24-2014, 03:18 PM   #2
Default Re: Leaking coolant
Cracked block. TIG welding if you can find someone who will work on it in the car.
95 sc2 coolant leaking zmarrott S-Series Tech 4 11-11-2014 07:47 PM
03 vue leaking coolant blue03vue Vue Tech 47 11-02-2009 08:39 PM
Coolant leaking!!! dhh3 S-Series General 4 11-05-2005 04:05 PM
96 sc2 with coolant leaking justinkr58 S-Series General 2 10-01-2005 04:40 PM
Coolant Leaking astringer Vue Tech 11 10-07-2004 08:23 AM
