Old 11-17-2014, 08:20 AM   #1
numonekobefan
numonekobefan has a spectacular aura aboutnumonekobefan has a spectacular aura about
numonekobefan's Avatar
Question Need Input and Output Shaft Torque Specifications for Manual Transmission
First off, I have done extensive searching throughout the forums looking for this information, but have been unable to find what I need.
I have a 1996 Saturn SL2 with a 5 speed manual trans, and I recently welded the diff pin like many of you guys have done. I am now in the process of putting the transmission back together, but I can't seem to find the input and output shaft nut torque specs anywhere. I have found them for the automatic, which were 111 ft-lbs, but I don't know if it's the same for the 5 speed.
Does anyone know what the torque specs should be? Thanks!
Add to numonekobefan's Reputation
Rate the quality of this post and help numonekobefan reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
numonekobefan is offline   Reply With Quote
Old 11-17-2014, 08:34 AM   #2
Default Re: Need Input and Output Shaft Torque Specifications for Manual Transmission
111ft-lb use new nuts, clean shaft of all oil with acetone, When installing thread it on in a single smooth motion all the way to the torque setting. If youshift the trans into 2nd gear and then carefully take the clip off of the 5th-reverse selector rod which is under the same cover you can push the synchronizer to the right side of the car and select 5th gear, this will lock the input and output shafts so they will not turn. Do not mangle that spring clip!
Old 11-19-2014, 09:13 AM   #3
numonekobefan
Thumbs Up Re: Need Input and Output Shaft Torque Specifications for Manual Transmission
Thanks OldNuc!
Input/Output shaft nut size? cityhawk S-Series Tech 5 07-12-2012 07:10 AM
Transmission issues after input / output shaft nut replacement jcm S-Series General 9 07-16-2011 08:13 PM
Manual Transmission input shaft seal emsvitil Vue Tech 6 03-16-2011 05:05 PM
01 SL1 Input/Output Shaft Nut Questions OTB S-Series Tech 17 01-09-2011 10:28 PM
input and output shaft nuts bdobraj S-Series General 1 01-23-2009 02:53 PM
