Old 11-11-2014, 09:32 PM   #1
gnoon
gnoon is on a distinguished road
Default 94 sl1 wiring question
The instrument lights for my gauges as well as the lights in my center console quit working. I swapped out an instrument cluster from the junkyard with the same results. Does anyone have a wiring schematic of this part of the harness? Is there a common wire that feeds the lights in these areas?
Add to gnoon's Reputation
Rate the quality of this post and help gnoon reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gnoon is offline   Reply With Quote
Old 11-11-2014, 10:48 PM   #2
Default Re: 94 sl1 wiring question
There is a dimmer circuit for those lights. There is a wiring diagram in the 91-96 Haynes that is a 94-95 drawing. Check the DIM fuse in the inside fuse box, I/P Panel. Lower right side of center console.
Wiring Question KellysVue Vue General 0 06-28-2006 02:57 PM
Wiring an Amp Question jdog L-Series General 5 09-27-2005 08:00 PM
Wiring Question OvenRude Mods and Performance 3 06-04-2003 03:33 PM
wiring question Tmac Miscellaneous Tech 4 10-13-2002 09:59 PM
another wiring question grumpy Mods and Performance 0 01-11-2002 04:07 AM
