Old 10-09-2014, 07:03 PM   #1
brittiny88
brittiny88 is on a distinguished road
2002 SL
Default new ignition now it wont stay running
I have a 2002 sl and just got a new ignition for it. A couple months ago it started becoming difficult to turn the key over. After a while it started getting very hard to turn so I stopped turning it the whole way off and only turned it til the engine shut off. Last week it got turned the whole way and I ended up breaking the key off in it. We managed to get it to turn over but it didn't last long. My fiance thought he'd rig it for the time being but that didn't work out too well and now I had to get a new key plus ignition switch assembly thing. I suggested replacing the key first since reading all the posts about worn keys but was ignored. I told them about the anti theft system and how they might of tripped it cuz they burnt all three big green 30 amp fuses and when they attempt to start it it fires up then stops and won't turn over. They dumped fuel into some hose and it fired right up then shut off once it burned the fuel. So any suggestions or tips on trying something would be greatly appreciated
Add to brittiny88's Reputation
Rate the quality of this post and help brittiny88 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
brittiny88 is offline   Reply With Quote
Old 10-09-2014, 09:43 PM   #2
Default Re: new ignition now it wont stay running
Welcome to the world of factory theft deterrent systems. GM started adapting Passlock since 2000 to Saturns. When activated with the security light flashing quickly while starting, the injectors are disabled to prevent the engine from running. The ignition switch and lock cylinder rotating is detected by Passlock sensors while reading a resistor in the ignition switch to allow engine running. A new ign switch requires a Passlock relearn procedure, posted here many times. Replacing the lock cylinder and ign switch is just a straight forward routine but the relearn procedure is required to 'marry' the replacement ign switch with a different resistor for Passlock to operate. Once learned, Passlock allows injectors to operate. If the Passlock sensors surrounding the ignition lock cylinder isn't damaged (a three-wire assembly), replacing parts should be difficult. Relearn takes 30 minutes.
1995 SC2 wont stay running GreaseMonky S-Series Tech 12 05-15-2012 01:07 AM
saturn wont stay running!!! twincharged S-Series General 10 03-20-2012 09:23 PM
97 saturn wont stay running countrygirlcna S-Series Tech 3 02-25-2011 07:23 PM
my car wont stay running and idky scrapmedallord S-Series Tech 1 02-16-2009 10:54 AM
car wont stay running pkuptrk Miscellaneous Tech 1 01-04-2003 10:06 PM
