Old 09-27-2014, 06:02 PM   #1
bumpdraft
bumpdraft's Avatar
1998 SW2
Default 98 SW2 Roof Leak near Hatch
Ď98 SW2 Roof Leak onto the Headliner near the Rear Hatch
Been leaking so long stalactites are forming
Old pic from before I tried any fix:
I searched and found,
http://www.saturnfans.com/forums/sho...d.php?t=138214
^this 2009 thread does not say if the leak was fixed.
Anybody have that leak and was able to fix it? Thanks-
Today, I cleaned and smeared 3M WindoWeld over the body seam:
Like my SC2, the leak could be from leaking little foam gaskets around the nylon inserts for the trim screws.
Prying up the roof trim:
...and the next to last trim screw is under the side glass. Iíd probably have to break the tab off the trim...
Competition Clutch 10Lb. Flywheel. 14 stalls to date (and loving it)
Add to bumpdraft's Reputation
Old 09-29-2014, 12:46 PM   #2
hholbein
1997 SW2
Default Re: 98 SW2 Roof Leak near Hatch
Many years ago (6+?) I had a similar leak in the upper rear hatch area. In my case, I think it was the roof seams directly adjacent to the hinges. I cleaned up the dirt and worked some clear silicone caulk into the seams and bridged over it. Since then, not leaks in that area, although the seams under the rear tail lights also started leaking into the wells behind the rear wheels.
Poor initial seam design funnels water into the car vs. shedding it and relies on sealant for everything.
Add to hholbein's Reputation
Old 09-29-2014, 07:46 PM   #3
bumpdraft
bumpdraft's Avatar
1998 SW2
Thank you - confidence is high. No leaks below, but I will check into it.
I think the headliner will clean up if I'm careful.
Old 02-16-2015, 06:55 AM   #4
dalenpalmer
dalenpalmer is on a distinguished road
At online, we have the best services for roof repairs. Before we can utilize better to examine the exact problem of the roof and start the work for the roofs.
veedone
Add to dalenpalmer's Reputation
Rate the quality of this post and help dalenpalmer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dalenpalmer is offline   Reply With Quote
Old 02-16-2015, 08:53 AM   #5
SL19302
SL19302's Avatar
2002 SL1
veedone
The leak is one of the easiest things to repair all you need is a small tube of silicone sealant and apply a light film on the body seams where the hatch door hinges are located.
CHECK YOUR OIL!
Add to SL19302's Reputation
Old 02-16-2015, 09:09 AM   #6
bumpdraft
bumpdraft's Avatar
1998 SW2
veedone
dalenpalmer, is the name of your business, "online." I tried to search for it but goooogle found "About 10,490,000,000 results."
Old 02-16-2015, 06:23 PM   #7
toggenburg
toggenburg's Avatar
^^ not judging, but the language structure seems to indicate someone from Sweden or thereabouts, talking about house roofs........IDK.
Old 02-16-2015, 06:34 PM   #8
bumpdraft
bumpdraft's Avatar
1998 SW2
Well, if it was an honest post and there was a language barrier, then I stand (a blockhead) ...
As a followup, that seems to have fixed the leak.
If it is also leaking around the Nylon inserts for the torx screws, then OldNuc's fix of injecting flow-grade WindoWeld around the Nylon insert with a syringe would be a professional-sounding fix (and a run-on sentence)
I am keeping an eye out for any additional leaks (besides the missing wiper shaft grommet, that is).
Old 02-16-2015, 07:47 PM   #9
johnny95sl2
johnny95sl2 will become famous soon enough
johnny95sl2's Avatar
1997 SW2
My 94 was leaking in the same place, I cleaned out that seam and re caulked it with gray rtv. Hasn't leaked since
Add to johnny95sl2's Reputation
Rate the quality of this post and help johnny95sl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
johnny95sl2 is offline   Reply With Quote
Old 02-17-2015, 12:55 PM   #10
hholbein
1997 SW2
That rear window wiper grommet decayed early on with my Saturn. I'm 6+ years into the retrofit of a quality neoprene rubber grommet from a hardware store. Cost is <$1. I forget the exact size, but the interior diameter was ~22mm; best approach is to take off the hatch trim, remove the motor and grotty grommet, measure the wiper motor shaft size and head down to a well-stocked hardware store for a replacement. Insert the new grommet in the hole first, and then the motor. A little silicone lube could help get it in there properly.
Old 02-18-2015, 09:09 AM   #11
hholbein
1997 SW2
Now that I can see your photos in your post, you may want to smear some Windoweld on the roof hatch seams that are on the other side of the hinges -- on the back and inside. That was where my leak was, and others as well. The water migrates to the corners when you drive around.
Fortunately, when the hatch is closed it covers up the stuff. I used clear silicone caulk, which is a bit less obvious.
Old 02-18-2015, 12:45 PM   #12
bumpdraft
bumpdraft's Avatar
1998 SW2
^At the time, I figured I could put another layer on and smooth it better. The first layer had to be built-up over the actual seam...and I had XL (made in ) neoprene gloves on
Did you mean the sheetmetal lap joint is the other side of the hinge? I do not see one. A design change?
Or, the driverís side could leak too? I patched both passenger and driverís side. (picture below)
leak in sun roof (I think) mjsmiley Vue Tech 13 05-24-2014 09:27 AM
Roof Leak!! Roof Rack the culprit? tmckinn Outlook General 77 06-26-2013 12:39 PM
Roof leak jdnglo Vue General 1 04-08-2013 07:55 AM
another roof leak possible sunroof saturnsctwo S-Series Tech 0 03-15-2010 12:39 PM
sun roof leak jenny Ion General 4 04-07-2008 07:19 PM
