Go Back   SaturnFans.com Forums > Models > Saturn Ion > Ion Mods
Old 02-03-2015, 02:00 PM   #81
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
Default Re: Whats in your Ion (show-off thread)
Originally Posted by goaliemo View Post
What I did with my muffler was bring it to a little hole in the wall exhaust shop that is reputable to my area. Older guy that is open 9-2, and has been in that spot for 40 years or something.
Charged me 100 for a magnaflow muffler and install/weld it on for me.
Could always look around to see if you have a shop like that over there.
there is a reputably exhaust shop near me also, but I like doing a lot of things myself.
only thing I cant do myself so far is tire mounting
03 ion-2 Sedan 5sp
♕KCCO
Add to kevin.st56's Reputation
Rate the quality of this post and help kevin.st56 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 02-03-2015, 04:16 PM   #82
goaliemo
goaliemo is on a distinguished road
2003 ION-1 Sedan
2006 ION Red Line
I do too, for the most part.
I don't know how to weld, and cant afford the tools to learn currently.
And the only other thing was swapping out my struts. Cant afford a GOOD spring compressor yet. Hoping to have that by summer though.
I'm just a guy that enjoys my Ions.
Try Google, first. Then ask.
Add to goaliemo's Reputation
Rate the quality of this post and help goaliemo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
goaliemo is offline   Reply With Quote
Old 02-04-2015, 02:08 PM   #83
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
replacing the struts were fun lol took a whole weekend, but the biggest issue I had was removing the top strut nut that screws onto the shock absorber.
we eventually had to take it to someone with a pipe wrench and an impact.
I had got a set of cheap compressors, where you use a ratchet to compress the spring.
other than that top nut, it was smooth sailing.
Almost didn't need the compressors when installing the lowering springs lol
harbor freight has good prices on a mig machine with flux core wire for mild steel. you can get carbon steel too.
I got mine for around $80 with a super coupon. had it for a year, and haven't used it yet lol
my senior year in high school had welding classes available to take, and so I did.
03 ion-2 Sedan 5sp
♕KCCO
Old 02-04-2015, 09:45 PM   #84
goaliemo
2003 ION-1 Sedan
2006 ION Red Line
I got to watch the guy at my shop do my struts, and it seems really easy with the compressor he had, and the air tools. lmao
Harbor freight has awesome prices on everything. Something to look into for future fun.
I did consider taking automotive or welding in my senior year, but at the time I was planning to go to college and dual enrolled in my culinary classes to try to get a jump start. College never did work out for me though.
Old 02-09-2015, 12:34 AM   #85
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
if everything cooperated well with me, it prolly would have taken a few hours to get everything done.
Its just that one top mount bolt on the end of the shock that was a huge set back.
thats where i got my 22gal air compressor, my mig welder, and a bunch of tool, including a 21" breaker bar i use for my lugnuts, and a torque rachet.
the compressor was on sale during one of their tent sales, which led me to buying it for $100 instead of the regular 180, but cant carry anywhere with me other than leaving it home bec its an oiled compressor, and you cant lay them down or itll ruin the compressor.
the welder with a coupon for 89 instead of 139 i think.
gotta love good deals lol
03 ion-2 Sedan 5sp
♕KCCO
Old 02-21-2015, 04:35 PM   #86
snakes
snakes has a spectacular aura aboutsnakes has a spectacular aura about
snakes's Avatar
2005 ION-1 Sedan
My latest mod on my 05 ION sedan. I love this Aeroforce tech interceptor . Still trying to figure out all the parameters . Finally got the steering column pod and installed it .
Add to snakes's Reputation
Rate the quality of this post and help snakes reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
snakes is offline   Reply With Quote
Old 02-22-2015, 07:34 PM   #87
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
not bad. gives it a nice visual appearence.
i like using my torque app on my phone when its needed.
just had a wheel hub bearing go out, and make a really loud humming sound, which gets louder at higher speeds.
passenger bearing was shot, and got it replaced with one from pull apart, which surprisingly was in good shape.
still need to do end links and tie rod ends, and finally, an alignment.
doing an alignment by hand will only take you so far.
one project im getting edged closer and closer to doing is a rear disc brake conversion (my drum brakes been giving me a ton of trouble since i replaced the shoes).
theres 2 way iv seen i can go about with this:
Option 1: get a complete RL or SS wheel hub/brake/axle beam swap, along with all 4 RL/SS brakes/rotors, and 5 lug hubs and wheels. more expensive but thorough route.
Option 2: get just the rear RL/SS brakes/rotors, get a rear caliper mounting bracket to mount behind the hub fabricated, and take the rotors to a shop to drill a 4x100 lug pattern into them. much cheaper method, and get to keep current 4x100 pattern setup.
03 ion-2 Sedan 5sp
♕KCCO
Old 02-22-2015, 08:21 PM   #88
snakes
snakes's Avatar
2005 ION-1 Sedan
Thank you! I want to look into the Bluetooth/ iPhone option. Sorry to hear about your hub bearing . I know it's onlya matter of time that I start having mine go out . The brake conversion I'm interested in also . I haven't researched it yet. For some reason my image in the thread uploaded sideways, lol
Old 02-27-2015, 03:25 PM   #89
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
im holding off the idea of the conversion for now since I finally have the self adjusters to work correctly, rather them disassembling itself and breaking the drum internals.
I still am interested into the idea, but its not as pressing now.
what is pressing at the moment is getting my exhaust manifold replaced, and fixing my downpipe.
I hit a roadkill and it broke a coupler that was added and the it occasionally separates, and make the noise ridiculously overwhelming.
I have a couple of tiny welds on it to hold it for now until I can eventually remove it, and get it welded back together.
03 ion-2 Sedan 5sp
♕KCCO
Old 03-30-2015, 02:58 PM   #90
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
my recent trip to pull apart, I got lucky to come across a 06 ion with the LE5 (2.4l) engine, which happen to have the oem fog lights, and a silver gauge cluster.
grabbed the bumper grill and fog lamps, and took apart the gauge cluster and grabbed just the gauge faces.
I got the gauge faces swapped, taking my circuit board from my cluster, and placed it onto the new faces, but missed one important step: the odo screen.
there is a wide ribbon cable from the circuit board to the lcd at the bottom of the speedo for the odo and milage, and ended up ripping it off, and almost no possible way to get it fixed.
Other than that mishap, it looks great, even better with the blue LEDs.
Gauges and everything else works with no issues, just cant see my milage, when cruise is set, when to change oil, or when running low om fuel (gotta rely on the gauge now).
Also put my personal touch to the speedo too
the lil sticky not, I wrote my last known milage (~227800), and zeroed out my GPS milage, so all id have to do is add what my gps has to the last known milage.
The gps stays with the car, and is never turned off while driving.
I have yet to install the fogs, but I will after I check them out for any damage.
03 ion-2 Sedan 5sp
♕KCCO
Old 04-01-2015, 10:35 AM   #91
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
got the fogs installed, along with the bumper grill.
replacing it was a lot easier than expected, and taking the bumper off made a huge help.
one of the lenses had a broken mount, which I got fixed with some JB Weld.
Just needs bulbs now, which I will be ordering this weekend.
are they H11 or 881? im getting mied results on what type of bulb they are.
also debating on either darkening them, or opening them and painting it gloss black.
03 ion-2 Sedan 5sp
♕KCCO
Old 05-08-2015, 12:21 AM   #92
Samtherecordman
Samtherecordman is on a distinguished road
Samtherecordman's Avatar
2007 ION-3 Quad Coupe
Originally Posted by NickL30 View Post
I might be doing this wrong but this is what's in my Ion! First picture was last week when I jam packed the trunk full of mulch. This week is an AC electrical wire! Technically it is what's in my Ion!
I am speechless in front of the pictures.... LoL Very impressed!
Saturn Ion 3 Quad Coupe 3 with Sports Appearance package with Aura Pro Bass Shakers under the front seats, Kenwood Excelon Mono Amplifier and Infinity Kappa Perfect and I'm In Heaven!!!!
Add to Samtherecordman's Reputation
Rate the quality of this post and help Samtherecordman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Samtherecordman is offline   Reply With Quote
Old 06-26-2015, 01:24 PM   #93
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
ok guys, im stuck on what set of rims to get.
the bronze Racing Harts I got are getting cracks for whatever reason, and JB Weld isn't holding up very well.
Heres the options. they are all 17"
one of them has a good tire on them.
all 4 of these has tires, but are about 40% tread left.
These all have newish tires on them, and were painted. used to be chrome
03 ion-2 Sedan 5sp
♕KCCO
Old 07-04-2015, 01:49 PM   #94
that1man
that1man is just really nicethat1man is just really nicethat1man is just really nicethat1man is just really nicethat1man is just really nice
2006 RELAY-2
2007 ION-2 Sedan
dirty carpet
Add to that1man's Reputation
Rate the quality of this post and help that1man reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
that1man is offline   Reply With Quote
Old 09-19-2015, 11:20 PM   #95
06_Ion2
06_Ion2 is on a distinguished road
06_Ion2's Avatar
2006 ION-2 Quad Coupe
To far for me as well, otherwise I would be making an offer.
If you do part out though, I want those stage 2 axles!
and probably the coilovers!
Axles were only $400. Sent DSS some from a junk yard, have less than $500 in them.
VISIT MY CARDOMAIN --> http://www.cardomain.com/ride/2259877
s256 turbo, vulcan intake, exedy clutch, 8.9:1, camed, eagle rods, 2.4 tb, B&G coilovers, patriot head, stage 2 axels 418whp 2.2 :)
Add to 06_Ion2's Reputation
Rate the quality of this post and help 06_Ion2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
06_Ion2 is offline   Reply With Quote
Old 10-25-2015, 04:19 PM   #96
Patskeeper1
Patskeeper1 is on a distinguished road
Patskeeper1's Avatar
2006 ION-2 Sedan
Enkei K-55 rims and a Kenwood head unit is what I have so far.
Add to Patskeeper1's Reputation
Rate the quality of this post and help Patskeeper1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Patskeeper1 is offline   Reply With Quote
Old 10-28-2015, 11:17 AM   #97
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
I like the blue on those lol.
That's something I thought about doing with my wheels is I were to get a 2 tone set
This is my current set now, which I need to get new tires for.
Will just take the tires from my previous set, since they only have around a couple thousands miles on, and put them on these.
Enkei RS-6 17" with the large center caps.
things to do:
Replace tires on Enkeis.
Replace either just the LCA bushings and balljoint, or the whole LCA.
Replace swaybar bushings (with urethane if possible).
Check/replace inner tie rods to see if source or wheel shake.
03 ion-2 Sedan 5sp
♕KCCO
Old 10-29-2015, 07:14 PM   #98
Patskeeper1
2006 ION-2 Sedan
Yeah, that's two of the reasons I got these rims. The blue lip/center cap and I was able to use the same tires that were already mounted on the steelies.
Those 17's are clean. Really nice, not too flashy.
Old 10-30-2015, 05:31 PM   #99
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
yea, it gets pricey getting larger rims.
I had originally 15" steelies also, but those tires were getting bad, so it was time for new tires anyways.
however, this is my third set of rims too.
the first set I found at pull apart without checking them, and finding out they are badly bent, and one cracked.
The second set were good, but ended up getting cracked after use. these were lightweight performance rims, so my guess is they weren't capable for daily driving, expecially south Louisiana roads.
These are good, but has loads of curb rash on them. I seen videos where you can use bondo to fill in the gaps and scraps, sand it down smooth, and repaint over it with the matching color, unless your recoloring them.
03 ion-2 Sedan 5sp
♕KCCO
Old 10-31-2015, 12:18 PM   #100
06_Ion2
06_Ion2's Avatar
I've had 2 sets of 17s and went to 16s because the 17s use to get bent on potholes. Plus the 16s have more sidewall so the ride is more forgiving. If you can get it low enough 16s or 15s don't look too bad.
The Saturn S-Series Aftermarket Sound System Show-off Thread. papoopeepoo S-Series Mods 11 05-09-2012 01:40 PM
Whats next? toork Vue General 23 02-05-2012 10:57 AM
Follow up thread to the ignition key cyl thread Scott Peterson S-Series Tech 3 06-09-2010 08:00 PM
New Guy Here, Whats Up King31 S-Series General 5 05-24-2004 10:27 PM
POST Miami Auto Show Info On SUV (New Thread) CVT SCDYNE Vue General 18 03-04-2004 01:43 PM
