Go Back   SaturnFans.com Forums > Models > Saturn Ion > Ion Mods
Old 11-24-2014, 04:56 PM   #41
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
Default Re: Whats in your Ion (show-off thread)
Originally Posted by Clyderp View Post
It is a 2.2 with 127,000 miles. As for the LSJ suspension, I was looking on different sites, and it said it was only for the redline... Would that require a lot mods to get it to work?
look for cobalt ss struts. same fitment as all the ions.
cobalts and ions both have very same setup, since the cobalt is based off of the ion.
instead of me getting the fe5s, i got kyb excel-g shocks, and megan racing springs.
id like to lower a little more to make it look more flush, but these new tires actually look better on than the old tires on the cp-10s, and i think these sized tires (205/45/17) i find is a better size than the stock 15s (196/60/15).
it handles a lot smoother, and speedo is dead on accurate.
all i need to do now is look into eventually getting new front rotors, rear brakes need to be changed since they are becoming noisy, and new exterior door panels.
and clyderp, your front led strips are extremely cleverly placed, why have i not thought about putting any there lol
03 ion-2 Sedan 5sp
♕KCCO
Add to kevin.st56's Reputation
Rate the quality of this post and help kevin.st56 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 11-25-2014, 02:50 AM   #42
goaliemo
goaliemo is on a distinguished road
2003 ION-1 Sedan
2006 ION Red Line
You need a conversion kit with the fe5 though. Crate engine depot sells them. Even the redline needs the kit. Its a different top hate I believe.
I'm just a guy that enjoys my Ions.
Try Google, first. Then ask.
Add to goaliemo's Reputation
Rate the quality of this post and help goaliemo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
goaliemo is offline   Reply With Quote
Old 11-25-2014, 03:11 AM   #43
goaliemo
2003 ION-1 Sedan
2006 ION Red Line
Correction- I was wrong, they sell them ion/cobalt/hhr specific now. Sorry.
Old 11-25-2014, 02:09 PM   #44
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
just about everything powertrain and suspention is the same across the ions, cobalts, some hhrs, and pontiac g5. there is also the cavalier (03 and up), some saabs, and pontiac grand ams (03 and up) that also have the ecotech engines, but have limited compatability with as far as anything around the enging. in the 03-07 era (not sure about newer than 07) ecotechs were very commonly used in GM cars. the reason why saab is included is bec GM had partial ownership of saab, before they went bankrupt due to terrible designs and very low sales.
03 ion-2 Sedan 5sp
♕KCCO
Old 11-25-2014, 09:19 PM   #45
ion skater6912
ion skater6912 is on a distinguished road
ion skater6912's Avatar
2005 ION-2 Sedan
not to say you're completely wrong there but it seems between the cobalts and ions GM in their infinite wisdom changed just enough to be a pain in the ass trying to get cobalt parts on an ion while still using the same essential power train.
FE5s you need to use ion upper mounts (you can buy the kit but in reality its cheaper to buy the shocks/struts for ~ $315 and whatever springs you want)
the length of the cat back is different (cobalts are slightly shorter i believe)
different diameters in the intakes
stuff like that, it can be made to work, just not bolt right up
2005 ion sedan
Tsuedo exhaust, 17" motegi ff7s, eibach springs, copertop stb, recaros, ported LSJ manifold, ZZP downpipe, coupe front end swap
Add to ion skater6912's Reputation
Rate the quality of this post and help ion skater6912 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ion skater6912 is offline   Reply With Quote
Old 11-26-2014, 09:06 AM   #46
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
there are tid bits of things that are slightly different between the vehicles.
one example is that the muffler on the 'balts have 2 hangars, and the ions have 1. idk if the ions hangar is the same possition as one of the 'balts hangars tho.
iv also learned the hardway that wiper linkages are different in size between the two also. 'balts have shorter linkages than the ion, but luckily, the driver wiper mount is in the same position as the ions. youll just be left without a passenger wiper (not needed, right? lol).
03 ion-2 Sedan 5sp
♕KCCO
Old 11-26-2014, 03:34 PM   #47
goaliemo
2003 ION-1 Sedan
2006 ION Red Line
The FE5 shocks and struts will bolt right up. But you need the Ion top hat, and longer sway bar end links.
I found a set for 170, but im looking into Koni Yellows now.
Old 11-26-2014, 04:39 PM   #48
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
just reuse the old ones, unless theyr damaged and get moog end links.
last i seen, konis were expensive as hell.
03 ion-2 Sedan 5sp
♕KCCO
Old 11-27-2014, 11:46 PM   #49
goaliemo
2003 ION-1 Sedan
2006 ION Red Line
Yes, they are.
But if you read the reviews, theyre also a better product.
Im staying up tonight to watch ZZPs website.
I want the brembo upgrade kit. Maybe a new intake, if the price is right.
A phenolic spacer, and ill probably end up with other crap. Because wanna be racecar. LMAO
If I can get those Konis for under 600, game on. Everything else can wait then.
Old 12-01-2014, 05:29 PM   #50
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
dont forget a loud muffler with ressinator del
03 ion-2 Sedan 5sp
♕KCCO
Old 12-02-2014, 02:22 AM   #51
goaliemo
2003 ION-1 Sedan
2006 ION Red Line
When I bought the car, it was straight piped...NO...just no.
Old 12-03-2014, 05:49 PM   #52
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
oh god.
my first muffler, was a magnaflow #14829, i had the res del, and it sounded great.
Then i added a cherrybomb glasspack in place of the res, and it made it super quiet.
then i got the whole cat back replaced with a kit, but for a while, i had to drive it with the exhaust halfwar chopped off, leaving the glasspack on, and the exhaust chopped a just before the bend to go over the rear axel. it sounded good, but was rediculously loud.
Now i have the 2.25" catback, but still have the stock header and DP, and it sounds good without being too loud.
What i really need done, hopefully soon, is to replace my header.
I want the LSJ DP, but i cant exactly just add it bec the bolt flange at the end of the DP is a 2 bolt, and the start of the DP that attaches to the DP is 3 bolt, so i would have to chop off the 2 bolt on the DP (cant do the catback bec its stailess steel), and weld on a 3 bolt flang to it.
i wanted to get the loud mouth exhaust for a cobalt, but there are some slight differences between the ion and balt's exhausts, and its almost $400 on ebay for it.
03 ion-2 Sedan 5sp
♕KCCO
Old 12-04-2014, 10:55 AM   #53
goaliemo
2003 ION-1 Sedan
2006 ION Red Line
oh god.
I just ordered a new header/dp for the car. If I can get everything out in one piece, it will be up for sale as I'm trying to get a new motor.
Old 12-04-2014, 02:49 PM   #54
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
i may look into the dp.
ill just have to dust off my welding skills, and find a flang to weld on lol
03 ion-2 Sedan 5sp
♕KCCO
Old 12-05-2014, 03:00 AM   #55
goaliemo
2003 ION-1 Sedan
2006 ION Red Line
I'll give yuh first dibs on it if yuh want it when the time comes.
Old 12-05-2014, 02:41 PM   #56
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
sounds good.
Thatll give me something else to add to my to-do list lol
I really need to get my back brakes done, and fix my GF civic and sell it
03 ion-2 Sedan 5sp
♕KCCO
Old 12-05-2014, 05:10 PM   #57
goaliemo
2003 ION-1 Sedan
2006 ION Red Line
sounds good.
I have a crap ton of parts I need to find time to install. haha
Use the civic as a down payment towards another Ion, let her experience a good car! LMAO
Old 12-07-2014, 04:11 PM   #58
bmxracerchamp12
bmxracerchamp12 is on a distinguished road
bmxracerchamp12's Avatar
2005 ION-3 Sedan
my ion is on hold for a bit. debating pulling my complete system out of the car and going radioless. the money i would get from all that stuff would take care of the fueling side of things for the car
2004.5 2500HD LT
-Tow Pig
2005 Turbo Ion 3 Sedan
-Lots of mods (parting out)
2004 Honda CBR 1000RR
-Summer toy
1995 Honda CX
-DD
Add to bmxracerchamp12's Reputation
Rate the quality of this post and help bmxracerchamp12 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bmxracerchamp12 is offline   Reply With Quote
Old 12-08-2014, 11:33 AM   #59
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
thats what i told her lol
and when something would happen to the car, i know how to fix it lol
shes more into the hatchbacks, and a small crossover suv.
she wants either a dodge caliber, hyundai accent hatch, or a buick encore.
i suggested a mini cooper, but she doesnt want that lol
03 ion-2 Sedan 5sp
♕KCCO
Old 12-08-2014, 02:18 PM   #60
goaliemo
2003 ION-1 Sedan
2006 ION Red Line
Saturn astra
The Saturn S-Series Aftermarket Sound System Show-off Thread. papoopeepoo S-Series Mods 11 05-09-2012 12:40 PM
Whats next? toork Vue General 23 02-05-2012 09:57 AM
Follow up thread to the ignition key cyl thread Scott Peterson S-Series Tech 3 06-09-2010 07:00 PM
New Guy Here, Whats Up King31 S-Series General 5 05-24-2004 09:27 PM
POST Miami Auto Show Info On SUV (New Thread) CVT SCDYNE Vue General 18 03-04-2004 12:43 PM
