Old 08-20-2014, 03:03 PM   #1
TheSoberDude
TheSoberDude is on a distinguished road
Default Headlamp Issue, Possibly blown fuse?
I am new to this forum so I apologize if this issue has been dealt with. If there is a thread on this issue please direct me to it.
Saturn Ion 2005
When I have the car in drive, only the right side of my car has a working DLR in in OFF position shown below.
When I have the car in drive and I put the headlamps in Parking Lamps mode, both are on but dimmed.
This problem makes me believe that the bulb is actually fine and that it might be a fuse problem.
i.imgur.com/zbvwCkS.png
Please copy and paste the above link to see the diagram.
Any help with this issue is greatly appreciated.
Add to TheSoberDude's Reputation
Rate the quality of this post and help TheSoberDude reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TheSoberDude is offline   Reply With Quote
Old 08-20-2014, 03:57 PM   #2
ruley73
ruley73's Avatar
2007 ION-2 Quad Coupe
Default Re: Headlamp Issue, Possibly blown fuse?
Does your car have automatic headlamps? I'm guessing not since the switch for auto headlamps doesn't have an OFF position.
The front turn signals serve as DRLs on your Ion, not the headlamps. Please clarify what bulbs are doing what. There's no reason for the headlamps to operate at reduced brightness.
2007 Chevy Equinox LT 183K miles
Add to ruley73's Reputation
Old 08-20-2014, 07:20 PM   #3
Originally Posted by TheSoberDude View Post
I am new to this forum so I apologize if this issue has been dealt with. If there is a thread on this issue please direct me to it. Saturn Ion 2005... When I have the car in drive, only the right side of my car has a working DLR in in OFF position shown below. When I have the car in drive and I put the headlamps in Parking Lamps mode, both are on but dimmed. This problem makes me believe that the bulb is actually fine and that it might be a fuse problem. Any help with this issue is greatly appreciated.
Did you try checking for blown fuses?
Old 08-21-2014, 12:29 PM   #4
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
Inside fuse box is located in the center of the dashboard, driver side footwell. also, have you taken out the bulbs and checked them to see if they are bad? also check what kind of bulbs you have, and make sure they are the correct bulbs
headlights are 9007
front/rear turn signals, and break lights are 3057 or 3157
reverse lights are 921
sadly, idk what the foglights are.
03 ion-2 Sedan 5sp
♕KCCO
Add to kevin.st56's Reputation
Rate the quality of this post and help kevin.st56 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 08-21-2014, 04:45 PM   #5
2006 ion2
2007 ION-2 Sedan
Did you check the socket? Burns? Bent contacts?
2007 Saturn Ion 2
2003 Chevrolet venture lt
Add to 2006 ion2's Reputation
blown fuse paulo Ion Tech 2 12-29-2009 02:34 PM
Blown fuse replaced, a few days later blown again! Crazy C S-Series Tech 5 06-16-2009 09:56 PM
Blown Fuse 2 motttocs S-Series Tech 9 10-22-2007 10:31 PM
Blown Fuse?? Jon2887 S-Series Tech 3 03-05-2007 11:47 PM
Blown Fuse piratepress Miscellaneous Tech 3 07-23-2002 11:24 AM
