Go Back   SaturnFans.com Forums > Models > Saturn Ion > Ion Red Line
Old 08-19-2014, 07:13 AM   #1
4minc
4minc is on a distinguished road
Default 4 Ron my 2005 Redline?
I just picked up a 2005 Ion Redline. While changing out the serpentine belt I discovered that the crank pulley is a 4 rib pulley rather than matching the 5 ribs on the rest of the pulleys.
Anybody have any idea why this would be set up this way?
The belt that is on there currently has had the 5th rib removed on the entire belt.
I did some searching and was unable to see how having 'less' ribs is better than more.
Thanks
PS, I need the stock, 5-rib crank pulley if anybody has one!
Add to 4minc's Reputation
Rate the quality of this post and help 4minc reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
4minc is offline   Reply With Quote
Old 09-23-2014, 07:21 AM   #2
happy12
happy12 is on a distinguished road
Default Re: 4 Ron my 2005 Redline?
My 04 Ion Redline clutch pedal started going way down to the floor and I would shift let off the clutch pedal and the pedal would go up way past the normal position
[url=http://www.vceplayer.com/simulator/vce-download.html]http://www.vceplayer.com/simulator/vce-download.html[/url]
http://www.shms.edu/
http://www.ibm.com/us/en/
http://www.stanford.edu/
http://en.wikipedia.org/wiki/IBM
Add to happy12's Reputation
Rate the quality of this post and help happy12 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
happy12 is offline   Reply With Quote
Old 09-23-2014, 10:25 AM   #3
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
sounds like the clutch line needs to be vacuum bled (many threads on how to, one i think here in the RL section), and either the master cylinder rod is worn out, the retaining clip on the pedal is not pressed in all the way or worn, or the section in the pedal where the rod presses in is worn.
the master cylinder would have to be replaced, as the rod tip cannot be changed.
Check if the white clip on the pedal is pressed in all the way, while you have it resting on the rod. if nothing, then replace it.
Last i heard, the section the rod goes in can be replaced, but i never seen it for myself. if not, then a new pedal itself will cost you $200 from GM
By the way, instead of thread stealing, start a new topic...
03 ion-2 Sedan 5sp
♕KCCO
Add to kevin.st56's Reputation
Rate the quality of this post and help kevin.st56 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
2005 redline value vueredline0504 Vue Red Line 4 11-10-2012 11:00 AM
2005 VUE Redline vs 2009 VUE Redline SHMOKE Vue Red Line 27 03-22-2009 10:19 AM
2005 Blue Redline in IL. BexVUE Vue Red Line 1 02-27-2006 02:30 PM
Changes 2005 Redline? Genesisbreed Ion General 2 03-19-2005 01:28 AM
2005 Redline Top Speed... silverbullet Vue General 38 11-01-2004 11:43 PM
