Old 08-07-2014, 07:54 PM   #1
NickL30
NickL30 has a spectacular aura aboutNickL30 has a spectacular aura about
NickL30's Avatar
2004 ION-3 Quad Coupe
Default cruise control not working
Got an 04 Ion level 3. I bought it and the cruise did not work for me. Now my car is an auto to manual swap car and I read there is a switch on the clutch pedal that needs to engage and wondered if that was installed or if it is somewhere else. I cannot start my car without my foot on the clutch.
I know this problem also has something to do with the cars lights. I did check the one ground at the head lights on the drivers side that I could find. Sanded it shiney. Is there a ground behind the tail lights as well? Did not remove those yet and could not find a ground in the trunk for the tail lights.
Are there other locations I need to check out as well? Perhaps where the headlights plug in or behind the steering wheel?
Add to NickL30's Reputation
Rate the quality of this post and help NickL30 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
NickL30 is offline   Reply With Quote
Old 08-07-2014, 08:46 PM   #2
2006 ion2
2007 ION-2 Sedan
Default Re: cruise control not working
With a auto to manual swap, it'll probably never work again. There probably is no protocol in the bcm for the clutch switch. With an auto car, cruise only works with the car in a forward gear, and at least one main brake light in tact, and with the brake lights off, and going at least 25mph. With a manual car it has to be in gear (probably a forward gear, but I'm not going 25 in reverse to test this theory), with your foot of the brake and clutch pedals, and going at least 25mph. The sensors and wiring are so different, I doubt you will be able to get the car to work right, but good luck.
2007 Saturn Ion 2
2003 Chevrolet venture lt
Add to 2006 ion2's Reputation
Old 08-07-2014, 09:11 PM   #3
ruley73
ruley73's Avatar
2007 ION-2 Quad Coupe
This confirms that there is some sort of interaction going on between the BCM and the clutch switch if it is wired correctly. Do you know if the ECM was swapped or reprogrammed? If not, there's no way the ECM will allow the cruise to engage. Does the orange LED light up on the switch on the steering wheel when the button is turned on? If not, then the EPS (2A) fuse is blown or missing (which might also disable the electronic power steering).
Check the EPS (2A) and CRUISE (7.5A) fuses in the I/P fuse block. If one or the other is blown/missing then cruise will not work. I doubt this is the case, but it's worth a look. It's just hard to say what it could be. It all depends on if the manual trans conversion was done the right way as opposed to just rigging it up to make it work. Unfortunately, most folks don't go the extra mile when doing such modifications.
2007 Ion 2 Quad Coupe 5-speed manual 180K miles
2007 Chevy Equinox LT 191K miles
2018 Chrysler Pacifica Touring L 27K miles
Add to ruley73's Reputation
Old 08-07-2014, 11:00 PM   #4
NickL30
NickL30's Avatar
The little light does light up but the setting cruise control on the right side look pretty worn out so I wonder if the switch would just need replaced. I did check the fuses and they looked good.
When I first got the car the car was in limp mode due to the auto to manual swap. The person who did the swap never completed it I guess. I swapped in an ECM from a manual and all was well after I passlock matched the ECM to BCM. From what I understand the car was swapped out correctly. All the right changes in the right places from what I can tell. Can a disabled airbag light on the gauges deactivate the cruise as well? I am in the process of fixing one of the seat belts that was apparently blown (due to the ball bearing jingle) and I am hoping that is why the light is on so once that is fixed I hope the light goes away and somehow the cruise would work again.
I just figured that if the airbag is deactivated then the cruise would be deactivated as well some how.
Old 08-07-2014, 11:32 PM   #5
ruley73
ruley73's Avatar
The disabled air bag will have no effect on the cruise control.
cruise control not working xraytec1 Ion General 17 01-27-2019 11:48 PM
cruise control not working kris S-Series Tech 8 02-05-2014 12:22 PM
Cruise control, A/C not working Scout238 S-Series Tech 8 08-20-2008 11:42 PM
Cruise Control not working gfreek1 S-Series Tech 7 06-29-2007 12:07 PM
Cruise Control Is Working!!! BarnOwl S-Series Tech 2 11-10-2005 11:43 AM
