Old 07-30-2014, 06:45 PM   #1
Megine
Megine is on a distinguished road
Default Vue bcm possible ground or going bad?
Hello!
So I bought an '03 vue with a few problems that I believe relate to the bcm but am not quite sure.
1. Power steering works intermittently
2. Only one setting for my heat& a/c works, the others work intermittently
3. Cruise control doesn't work at all.
Also if the power steering is working at random the heat fan won't also work.
I'm confused to thinking it might be bad connection somewhere or just the bcm going. Could it not be the bcm at all and be just the pscm or the power steering motor?
Lastly I have an '03 donor vue and all the settings are the same on the donor except for abs. Will the part numbers for the bcms match?
if not if I replace the ECM and bcm from the same donor car will that work even if my bcms don't match
Thank you to anyone responding in advanced I know it's a lot of questions
Add to Megine's Reputation
Rate the quality of this post and help Megine reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Megine is offline   Reply With Quote
BCM Ground waynerruss Vue General 7 12-28-2015 01:24 AM
BCM BAd ground? Shockmeman L-Series Tech 3 06-13-2014 03:09 PM
BCM or GRound 01 L2 sparky1 L-Series Tech 5 05-17-2012 01:34 PM
i have a bad ground anasazi S-Series Tech 1 10-11-2006 02:19 PM
ground for amp jumpn Vue General 5 03-09-2005 10:12 AM
