Old 07-20-2014, 10:23 AM   #1
LazB
LazB is on a distinguished road
Question 97 SL2 Oil Leak
Hi all,
So I recently just entered the Saturn world by purchase of a '97 SL2. The guy I bought it from said the car burned a lot of oil so I found this forum and followed the MMO+Oil change tutorial. Needless to say while doing this I noticed small amounts of oil dripped from the car under the passenger side. Not sure where it's coming from but I have an idea I saw a bit of oil that seemed to be coming from the case. So from looking at the pics any suggestions?? Thanks!
Add to LazB's Reputation
Rate the quality of this post and help LazB reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
LazB is offline   Reply With Quote
Old 07-20-2014, 10:56 AM   #2
SL19302
SL19302's Avatar
2002 SL1
Default Re: 97 SL2 Oil Leak
Looks like the valve cover gasket is leaking around the timing cover area, The gasket does not look old however if it wasnt properly done with RTV on the T-Joints these engine leak in that area front and back.
CHECK YOUR OIL!
Add to SL19302's Reputation
Old 07-21-2014, 09:54 AM   #3
LazB
Thanks for the reply!
What do you suggest I do to fix this?
Old 07-21-2014, 10:25 AM   #4
el diablo viejo
el diablo viejo's Avatar
1994 SW1
The plastic covers are notorious for leaking. The best fix is to replace it with an aluminum cover from a 1994 or 1995. There are tons of threads regarding this. Have you checked for oil in the spark plug wells ?
97 sl2 a/t 104 K
Add to el diablo viejo's Reputation
Rate the quality of this post and help el diablo viejo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 07-21-2014, 12:13 PM   #5
LazB
I will be sure to check for that thread also during the MMO soak when I removed the plugs I didn't really notice much but I will double check them to see. Thanks.
Old 07-21-2014, 02:51 PM   #6
Usually, when the plastic valve covers warp and leak, they do that at the opposite end (driver side rear).
The aluminum cover is a permanent fix (and looks better, IMO). One of the better threads was started by Saturninin
http://www.saturnfans.com/forums/sho...d.php?t=187908
But if you want to 'cheap out' a bit, I'll bet whoever did your cover just did not put a dab of RTV at the front corners, or did not thoroughly clean the head surface before putting it on (and/or did not properly torque the cover on; it's something like 7 inch lbs and done in evenly in stages
Old 07-26-2014, 12:34 PM   #7
bushkanaka86
bushkanaka86 is on a distinguished road
I just replaced the plastic valve cover on my own '97 SL2 a few months ago. If you don't want to go to a junk yard yourself, contact Saturninin from that other thread and he sells the entire kit with instructions but a reasonable price. Worked for me!
Add to bushkanaka86's Reputation
Rate the quality of this post and help bushkanaka86 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bushkanaka86 is offline   Reply With Quote
Old 07-26-2014, 01:04 PM   #8
NWSaturn247
NWSaturn247 will become famous soon enough
NWSaturn247's Avatar
1993 SL2
I believe it is a torque setting of 89 inch pounds. I recently replaced my gasket and used a Harbor Freight $10 special torque wrench. If you get the aluminum cover, do not cheap out and use RTV in lieu of a proper valve cover gasket. I used a Felpro I got on Amazon for $23
1993 SL2 AT - 188k miles
running blend of various SOPUS oils & MGL3614
TCW3 dosed fuel
Goldie: a dame to kill for...watch out squirrels!
Add to NWSaturn247's Reputation
Rate the quality of this post and help NWSaturn247 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
NWSaturn247 is offline   Reply With Quote
Old 07-26-2014, 01:24 PM   #9
SL19302
SL19302's Avatar
2002 SL1
Replace the Valve cover with the Aluminum 94-95 unit and you will need a new gasket, Use RTV on the t-joints on the Timing Cover and only torque the bolts to 80 In/lbs The spec is 89 however if you break one of those off or your torque wrench isnt calibrated correctly it can turn into a bad day real fast.
CHECK YOUR OIL!
Oil Leak, Coolant Leak, Alternator, Compressor Bobcat124_23456 L-Series Tech 4 03-25-2013 09:13 PM
question about radiator stop leak helping a leak from the plastic end caps tmoncrief S-Series General 6 09-04-2012 01:51 PM
Colant Leak - Small leak turned into a big one Raysp30 S-Series Tech 3 03-02-2009 06:25 PM
Driver side leak & sunroof leak-common? Miss Holly S-Series Tech 3 01-06-2008 01:01 AM
evaporator core leak -- opinions on 'stop leak' products? brenspin S-Series Tech 12 01-30-2006 11:29 PM
