Old 07-19-2014, 11:02 AM   #1
cajun1965
cajun1965 is on a distinguished road
2007 ION-3 Quad Coupe
Default fuel leak when tank is full
2007 ION bought it used, am happy with the way it handles and drives. I noticed when Ifill the gas tank completely full that gas will leak out of the tank and I am not sure why. once it gets around 3/4 full the leak stops. I thought there was a recall on the fuel pump or something like that. would love some advice I am new to the Saturn world.
Add to cajun1965's Reputation
Rate the quality of this post and help cajun1965 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cajun1965 is offline   Reply With Quote
Old 07-19-2014, 01:33 PM   #2
eneloop
eneloop is on a distinguished road
Default Re: fuel leak when tank is full
Call the nearest Chevy dealer VIN in hand and ask if the fuel system recall has been done.
All the best
eneloop@yahoo.com
http://www.miata.net/garage/tirecalc.html
Add to eneloop's Reputation
Rate the quality of this post and help eneloop reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
eneloop is offline   Reply With Quote
Old 07-19-2014, 02:14 PM   #3
Did you try looking under the car to examine for any severe rust/corrosion anywhere related to the fuel system?
Old 07-19-2014, 08:24 PM   #4
2006 ion2
2007 ION-2 Sedan
sounds like you have a rusted pump retaining ring...
2007 Saturn Ion 2
2003 Chevrolet venture lt
Add to 2006 ion2's Reputation
Old 07-20-2014, 10:36 AM   #5
billysvue
Good call. I've seen that in other makes-easy place to collect moisture/corrode. Time for someone to take a closer look.
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Add to billysvue's Reputation
Old 07-20-2014, 10:42 AM   #6
billysvue
This issue?
http://www.autoblog.com/2009/11/04/g...ontiac-g5-mod/
The problem involves 2006 Cobalt and Ion model models sold or registered in Arizona and Nevada and 2007 Cobalt, G5 and Ion models sold or registered in Arizona, California, Texas, Florida and Nevada.
NHTSA says the plastic supply or return port on the cars' modular reservoir assembly may crack, potentially leading to a fuel leak that could cause cause decreased efficiency and performance. Worse, if that leaking gasolinecomes into contact with an ignition source of any kind, you could be looking at a Delta platform car-b-que.
To fix the fuel leak problem, company dealerswill replace the fuel pump module of affected vehicles free of charge. GM is also providing a special coverage for 2006 and 2007 Cobalt, G5 and Ion models in other warm weather states, and you can hit the jump to read over the NHTSA press release to see if you live in a participating location. GM hasn't yet provided a time frame for owner notification, but if you have questions you can read the official press release after the jump or call 1-800-630-2438 (Cobalt), 1-800-972-8876 (Ion) or 1-800-620-7668 (G5).
[Source: NHTSA]"
http://www-odi.nhtsa.dot.gov/owners/SearchSafetyIssues
'17 Suby Forester
Old 07-20-2014, 07:02 PM   #7
cajun1965
Thank you for the reply, I have not filled the tank up full again but will do so soon to see if I can tell where the gas is coming from. I did call local Chevy dealership that use to sell the Saturns, says they don't know about the fuel leak issue recall, but I will have verify where the car was originally sold at.
I will post again when I find out something with the gas issue. Once again thanks for the reply.
Old 07-20-2014, 07:16 PM   #8
2006 ion2
2007 ION-2 Sedan
Could also be a loose/cracked filler neck
2007 Saturn Ion 2
Old 07-22-2014, 10:33 AM   #9
cajun1965
All right, just came from under the car to look at fuel tank to find where the fuel is leaking from. It appears that it is coming from the filler neck on the fuel tank.
is there a fix for this or will i need to find a new / used tank to fix the issue.
Old 07-22-2014, 12:04 PM   #10
cajun1965
Here is an image of the fuel filler neck.
Old 07-23-2014, 08:27 PM   #11
NickL30
NickL30 has a spectacular aura aboutNickL30 has a spectacular aura about
NickL30's Avatar
2004 ION-3 Quad Coupe
You can buy a two part fuel tank repair mix from advance auto. I did that to a lawn mower gas tank and it has held up well and it is advertised for vehicles. 10.00 but honestly it might be just as easy to get the new tank. If it is covered under a recall then have them fix it.
Add to NickL30's Reputation
Rate the quality of this post and help NickL30 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
NickL30 is offline   Reply With Quote
Old 07-23-2014, 10:12 PM   #12
2006 ion2
2007 ION-2 Sedan
There is no recall for the filter neck cracking. It's not even a common/known issue with ions/cobalts.
2007 Saturn Ion 2
Old 07-25-2014, 08:48 AM   #13
cajun1965
Wrench Re: fuel leak when tank is full
Thanks for all the input and advice on the fuel tank issue. I have been digging around for replacement tanks and have not found a good source for the tank. If you know of any good web sites for replacement tanks would greatly appreciate it. i have found some used tanks but not sure if I want to go that way just yet.
I am going to try to patch the leak, just to see if I can, in the mean time I will be looking for a new replacement tank.
Old 07-26-2014, 12:14 AM   #14
2006 ion2
2007 ION-2 Sedan
Rock auto, all the major parts stores, dealerships. Anywhere else is a crap shoot for fit and quality.
2007 Saturn Ion 2
Old 08-09-2014, 01:07 AM   #15
ruley73
ruley73's Avatar
2007 ION-2 Quad Coupe
Add me to this list. I've been noticing a fuel smell for the last month or so. I just got around to inspecting for leaks tonight. Sure enough, there is a crack right along the seam where the plastic spout (the extension that the rubber section attaches to) is mated/molded to the main reservoir on the fuel tank.
The only new replacement fuel tank is that is available is the OEM part from a GM stealership. The part number is 20870462 and it retails for $695 ($481.05 discounted price). When I get a chance, I hope to patch it up good with some two-part fuel tank repair epoxy without dropping the tank, but I may need to drop the tank so I can properly prep the surface. I've had great results with the repair epoxy in the past.
2007 Chevy Equinox LT 183K miles
Add to ruley73's Reputation
Old 08-09-2014, 07:55 AM   #16
2006 ion2
2007 ION-2 Sedan
Everybody file complaints with nhtsa. There should bea recall on this if it's a widespread problem.
2007 Saturn Ion 2
Old 08-09-2014, 10:07 AM   #17
ruley73
ruley73's Avatar
I just submitted a complaint last night.
I have access to a plastic welder, so I'm tempted to use that instead of the repair epoxy. I probably won't get to it until sometime this next week.
Old 08-17-2014, 11:46 AM   #18
ruley73
ruley73's Avatar
I went ahead and installed a used fuel tank. I believe it was also leaking from the area circled in the first picture below. I was also happy to see that the fuel pump/module had already been replaced by a previous owner.
The two round parts you see in the picture below are molded into the fuel tank and are not serviceable. I'm not exactly sure what they are, but they appeared to be EVAP system check valves that let air/vapor (but not liquid fuel) vent from one side of the tank to the other as necessary. The purge canister also connects to these parts.
My car has federal emissions (option code NT7). All 2006-2007 Ions use this same fuel tank EXCEPT those with option code NU6. The 2003-2004, and 2005 fuel tanks are different from each other and different from 2006-2007 fuel tanks.
Another interesting thing that I learned was there is a check valve that resides in the fuel tank for the the filler neck spout. Once fuel goes in, it can't come back out.
2003 L200 fuel leak from top of tank flash1605 L-Series General 5 10-09-2015 08:12 PM
Ls100 fuel leak (tank issue) Solion L-Series Tech 0 06-03-2013 09:02 PM
L100 fuel tank leak gbroughton46 L-Series General 14 10-12-2011 10:58 PM
better MPG on a full tank? macmdb S-Series General 8 02-29-2004 06:44 PM
00 SW2 Like no gas, but has a full tank jm0397 S-Series Tech 15 07-09-2003 01:15 PM
