Old 07-10-2014, 11:40 AM   #1
Darkone
Darkone is on a distinguished road
Default Wiring frustration saturn SW2 1995
I don't like recreating threads like this but the old one was getting confusing and old so am making a new one that is a bit clearer on what I need help with.
I have to wires dangling down by the intake down by the starter. One is white and the other is black. I be leave they go to the icm from what I have read around but I just don't no where they go from the icm or I could be wrong and it goes to the injector/fuel rail are. And my symptoms are I have a hesitation after it shifts gears at 35 mph. No stallout. Then when I almost to WOT it takes of like a bad out of hell. But if I get it anywhere close to closed throttle it idles way down. Am also pretty Shute it's eating more gas to. Ive replaced map, ects, o2, tps, iac, sensors. compression test cheated out fine. And PCM is throwing no codes. Any help will be helpfull.
Add to Darkone's Reputation
Rate the quality of this post and help Darkone reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Darkone is offline   Reply With Quote
Old 07-10-2014, 02:51 PM   #2
blue92
blue92 will become famous soon enoughblue92 will become famous soon enough
1992 SL1
Default Re: Wiring frustration saturn SW2 1995
My guess is tis for one of the sensors located in that area.
knock sensor
oil pressure
canister purge sensor
rear o2 sensor
vss sensor
take a picture and post it.
92 SL1 original owner
94 SL2 Homecoming
98 SC2 White Hot
02 SC2
Add to blue92's Reputation
Rate the quality of this post and help blue92 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
blue92 is offline   Reply With Quote
Old 07-10-2014, 05:08 PM   #3
Darkone
Ok I'll get on it as soon as I can get a jack from my father inlaw. Also the knock sensor is good plus the kps is to laughing out loud wouldn't have EFI WITHOUT IT.
Old 07-10-2014, 05:17 PM   #4
Darkone
And from my last view from looking down all the sensor down there had there respectave wires going to them. Pluse any pictures I've looked up don't even show wires that collie or that long going down there. Makes me wonder if the wire is snapped and didn't break of from a connector. But ok I'll get a good picture.
Help! 1995 Wiring for my Saturn buggy Project! scouthead S-Series Tech 14 02-13-2010 02:35 PM
egr frustration white-sl2 S-Series Tech 20 03-21-2008 07:51 AM
Wiring diagrams for 1995 SL2 tacokyle S-Series Tech 4 03-22-2007 11:56 AM
1995 SC2 Ignition Switch Wiring Problem SCATPK L-Series Tech 6 05-16-2005 09:11 PM
Beyond Frustration with my car.... BrenSaSC2 S-Series General 5 10-04-2003 04:19 AM
