Old 07-09-2014, 08:48 AM   #1
jper
jper is on a distinguished road
2002 VUE 3.0L
Question No turn signals or hazard lights after towing trailer
Hi everyone,
We hooked up a trailer to our 2002 Saturn Vue AWD and, at first, the lights were working great. About halfway through our trip, however, we noticed that our turn signals were no longer working on the trailer or the car. Once we reached our destination and removed the trailer wiring kit for the lights, we were hoping the lights would start working again, but they did not. I assume we've shot some fuses, but I don't know how to find which ones or how to replace them. I did go ahead and replace the hazard switch already (using the instructions I found on this forum - thanks!), and that sadly did not fix the problem. Do you agree this is likely a fuse issue? If so, could someone please provide instructions on how to replace the fuses?
The hazard lights make no sound when the switch is pressed, nor do the turn signals make any sound when the turn signals are turned on.
Add to jper's Reputation
Rate the quality of this post and help jper reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jper is offline   Reply With Quote
Old 07-09-2014, 10:09 AM   #2
vasy
vasy is on a distinguished road
2007 VUE Green Line
Default Re: No turn signals or hazard lights after towing trailer
Check fuses.
They are located on the passenger left kick panel area.
Once you open a door, it has a guide printed on it. Another area fuses are located is under the hood, top(ish) right side. It is a marked rectangular black box with fuse and relay diagram on the bottom.
You may have overloaded the system with the kit.
Add to vasy's Reputation
Rate the quality of this post and help vasy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
vasy is offline   Reply With Quote
Old 07-09-2014, 12:10 PM   #3
jper
2002 VUE 3.0L
Thanks very much. For anyone new to automotive care like myself, I found the following video helpful: carcarekiosk.com/video/2004_Saturn_Vue_2.2L_4_Cyl./fuse_interior/replace
My turn signals now work!
Failure: turn signals/hazard lights mjhstl L-Series Tech 2 04-19-2014 04:11 PM
No turn signals or hazard lights sponger246 S-Series Tech 3 11-27-2013 02:02 PM
hazard lights not working, but turn signals are fine carangil S-Series Tech 3 10-02-2011 10:06 PM
Hazard switch broke, now turn signals don't work. Mgg4591 S-Series General 7 09-27-2010 09:54 PM
91 sl2 turn signals hazard not working speed racer S-Series Tech 0 03-19-2009 03:59 PM
