Old 07-09-2014, 08:21 AM   #1
Brian Mabee
Brian Mabee is on a distinguished road
Default Outlook XR - PO 496 DTC - Evaporator Emission High System High Purge Flow
Good morning - based on a quick scan it looks like I have to replace a valve or sensor. What part is actually needed , how easy is it to replace (are instructions available inline?) and what is the approximate cost for this part.
Will this also eliminate difficult starting after fuelling up to a full tank?
Thank you
Add to Brian Mabee's Reputation
Rate the quality of this post and help Brian Mabee reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Brian Mabee is offline   Reply With Quote
Old 07-12-2014, 12:17 PM   #2
Penrod
Penrod has a spectacular aura aboutPenrod has a spectacular aura about
Penrod's Avatar
2009 Outlook XE
Default Re: Outlook XR - PO 496 DTC - Evaporator Emission High System High Purge Flow
Looks like the easiest part is the purge solenoid. I haven't had this issue but if you can see the attached file it doesn't look like it's in that hard of a spot to get to. For my 09 Outlook XE on rockauto.com the part is about $40. The other part look like it could be the fuel tank pressure sensor which itself doesn't look hard but you have to drop the gas tank. I'm sure someone who knows more than I do will chime in and hopefully narrow it down a little better. Good luck.
Add to Penrod's Reputation
Rate the quality of this post and help Penrod reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Penrod is offline   Reply With Quote
failed emission -HC /CO2 too high squiggle S-Series Tech 30 11-27-2013 12:16 PM
1995 SL2 High Hydrocarbon Emission Eaglescrest S-Series General 13 07-28-2013 10:43 PM
Code is P0469 "Evap emissions high purge flow fault" BuddyP Aura General 17 04-01-2010 04:51 PM
high flow cat 97saturnsc2 S-Series Mods 3 03-27-2007 10:48 PM
High Flow Cat + OBD-II?... Rob1998SL2 Mods and Performance 7 04-01-2004 02:48 AM
