Old 07-07-2014, 01:18 PM   #1
datlas
datlas is on a distinguished road
Default Fuel Tank Leaking from "weep hole??"
Long story short. My 1998 SL died on the road last week, felt like it was out of gas. AAA towed me to the mechanic.
My mechanic said it was the fuel pump and replaced it. Curiously, the same problem happened 3-4 years ago but I suppose these after-market fuel pumps don't have a good lifespan....anyway....
The car works fine now, but when I went to fill the tank over the holiday weekend, I got a BIG surprise....gas started streaming out of the back of the fuel tank where the "fill fuel" line goes in. I figured the shop had not tightened the clamp there properly. I don't have ramps so I could not really verify this. After about 3-4 gallons the leak stopped (and the fuel gauge went to 7/8). Car works fine and no more leaking over the weekend.
I just got off the phone with the mechanic and he said they tightened the clamp, but he claims the leak is coming out of the "weep hole" on the black plastic hose that goes into the fuel tank. He said he put some epoxy over that and it should all be ok.
I am hoping what he says is correct, but somehow this does not sit quite right with me.
Suggestions or comments??
Add to datlas's Reputation
Rate the quality of this post and help datlas reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
datlas is offline   Reply With Quote
Old 07-07-2014, 03:20 PM   #2
Default Re: Fuel Tank Leaking from "weep hole??"
No, it is not. The vent and fill hose are designed to be removed from the tank after you disconnect them by removing the screws you see through the fill door. He has now blocked the vent system and probably flooded the charcoal canister.
Old 07-07-2014, 03:28 PM   #3
datlas
Ruh Roh. I don't have a ramp as above so I have to rely on others. Can you advise what will happen if I drive it like this? I am hoping it's ok in the short term.
Old 07-07-2014, 04:19 PM   #4
You can buy as set of Rhino Ramps at the parts store for about $50.00 or so and then you can look and see what is going on under there. Should be OK driving it though.
98+fuel system and tank issues
http://www.saturnfans.com/forums/sho...d.php?t=160989
This thread has drawings and links to other drawings that explain how all teh parts are supposed to play well together. 98+fuel system and tank issues
Old 07-08-2014, 03:49 AM   #5
sallydriver
sallydriver is a name known to allsallydriver is a name known to allsallydriver is a name known to allsallydriver is a name known to allsallydriver is a name known to allsallydriver is a name known to all
sallydriver's Avatar
1993 SW2
Where are you located? We could probably relate a mechanic in your area who actually CAN work on Saturns.
Or, if you're getting some ramps, you can start working on it yourself! I've found the hardest part of any hard repair is telling yourself you can do it. Especially with these forums available.
1998 Red SL 5spd "The Right Honorable Duke Farnsworth the Functional of Clearfield":165,000 miles
1999 Forest Green SL2 5spd "Sally": 307,100+ miles
1993 White SW2 5spd "Steve": 234,984 miles
Add to sallydriver's Reputation
Rate the quality of this post and help sallydriver reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sallydriver is offline   Reply With Quote
Old 07-08-2014, 10:40 AM   #6
Rhino Ramps, $49.99 at Advance Auto. Order online, but choose the "pick up in store option" if there's one close to you, to avoid waiting and shipping charges.
Apply a coupon code from retailmenot.com when you are checking out.
For example, you can use code TRT30 for 30% off, making it $35 for the ramps.
I don't know what you are paying for oil changes, but the tools you need to change your own oil are probably less than two or three oil changes.
Also, you can be sure the right parts will be used. Check your part number for the fuel filter the mechanic installed... there are only a couple that will provide the proper fuel pressure for '98-02 Saturn S-series (Wix 3371 or equivalent, such as the NAPA branded 33731, OEM from dealer, and GK Industries GF1846)
If he used Fram (G9370) or Purolator (F65501) or similar, expect fuel pressure issues in the future.
Old 07-08-2014, 11:47 AM   #7
If I had the chance to do it over again, I wouldn't get the mini-ramps the parts stores sell.
$49.99 doesn't sound like such a good deal if you have Amazon Prime, http://www.amazon.com/RhinoGear-1191...dp/B006EGAIJ2/ ($55, 2-day free shipping and the tread is 10in wide).
Oh, hey these are $5 cheaper and should be just as wide: http://www.amazon.com/RhinoGear-1190.../dp/B006EGAIII
Nothing really wrong with the part store ramps, tread could be stickier for FWD's but AWD fix's that issue. My Outback looks like a fat man in a little coat on them, and my SC2 wasn't far off with 195's.
Old 07-08-2014, 01:24 PM   #8
OU812
OU812 has a spectacular aura aboutOU812 has a spectacular aura about
1996 SL1
AUTOZONE
RhinoGear/12000 lbs. RhinoRamps
Part Number: 11909
Alternate Part Number: 11905
Price: $44.99
Add to OU812's Reputation
Rate the quality of this post and help OU812 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
OU812 is offline   Reply With Quote
Old 07-08-2014, 01:39 PM   #9
Originally Posted by OU812 View Post
AUTOZONE
Part Number: 11909
Price: $44.99
Those are the exact same ramps /part number that I listed at $35 after the online coupon code
Personally, I prefer a jack and stands. Though it'd probably be a good idea to have both.
Actually, I plan on having a garage with a lift at the next/final house I have built.
Old 07-10-2014, 07:19 AM   #10
datlas
Thanks for all the suggestions. Currently under investigation.
In the meantime, I have a follow-up question/observation.
The car is running ok. But I seem to notice a slight decrease in power when going up hills and a little bit of a "shudder" and need to downshift earlier than before the repair. Is there a chance that the fuel tank is not vented properly causing this? Or something else that is obvious??
It runs ok otherwise. I have not refilled tank since repair, since I only drive 20-30 miles/day.
Fuel trim "index" vs "percent"? RobertGary1 S-Series Tech 4 12-22-2012 11:05 PM
While my "sunroof doesn't" gently weep... VTchemist Vue General 12 11-04-2009 10:49 AM
Transmission Drain plug hole "buggered up" roswell998 Miscellaneous Tech 4 11-24-2004 09:17 PM
"" Help "" goop in coolant tank Regal5575 S-Series Tech 17 09-01-2004 11:52 PM
