Old 07-03-2014, 12:41 PM   #1
snewport
snewport is on a distinguished road
Default outlook transmission fluid level
Just bought an 09 outlook. The short story is that the dealership told me that the transmission fluid level is not a checked by the dipstick. The correct way is to take out a bolt on the side of the transmission and add fluid until it comes out. If this is the case, why is there a dipstick? When I checked the level with the dipstick it just showed up on the tip. And yes, the engine was hot. Anyone have any insight? Thanks
Add to snewport's Reputation
Rate the quality of this post and help snewport reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
snewport is offline   Reply With Quote
Old 07-04-2014, 10:13 PM   #2
onefunkar
onefunkar's Avatar
2008 Outlook XR
2007 AURA XR
Default Re: outlook transmission fluid level
engine running? go thru each gear while running. i think gm figures no leaking its full. if leaking bring it in. normal usuage fluid doesnt get changed.
Add to onefunkar's Reputation
Old 07-05-2014, 09:11 AM   #3
Penrod
Penrod has a spectacular aura aboutPenrod has a spectacular aura about
Penrod's Avatar
2009 Outlook XE
According to the Haynes manual the only reason it would be low is a leak. The book tells you to do a drain and fill every 30K miles or 30 months. Doing this it tells you to fill it through the dipstick hole like most other vehicles.
Add to Penrod's Reputation
Rate the quality of this post and help Penrod reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Penrod is offline   Reply With Quote
transmission fluid level ddemier7 Ion General 7 04-19-2014 10:22 PM
Transmission fluid level awilson506 S-Series Tech 3 08-20-2012 10:43 AM
Transmission fluid level Tobygot S-Series General 3 09-25-2010 09:47 PM
Transmission fluid level dave991 Aura General 13 04-16-2010 03:28 PM
transmission fluid level check dyycxgm L-Series Tech 2 12-19-2007 10:33 PM
