Old 06-09-2014, 07:47 AM   #1
hawks000
hawks000 is on a distinguished road
Dizzy 2000 ls1 ignition switch issue
I am new to this forum and I signed up to see if anyone could help me out with my LS1 issue?
I have just inherited (had to rebuild engine) but finally got it done and went to crank it. it does does GREAT ( I am proud of me & my neighbor ) Anyway on to the issue. For one thing the key will come out at any position (which isn't a problem) but the problem is the key just wants to go to ACC & NOT OFF!! I took the cover off the steering wheel and beat on switch to try to get tumblers stuck and also sprayed lube inside it still didn't work. well while I was working on it the "dinger " got on my nerves!!! So I took the battery cable off to stop it .....the key NOW GOES TO OFF and works as it should?? So now my question is are they anything electrical that might would cause this ? I put the battery cable back on & it does't go back to OFF?
Thanks in Advance
Add to hawks000's Reputation
Rate the quality of this post and help hawks000 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hawks000 is offline   Reply With Quote
Old 06-10-2014, 09:54 AM   #2
Russet
2002 L-Series 3.0L Sedan
Default Re: 2000 ls1 ignition switch issue
Thanks in Advance
How many miles are on the Saturn? Could be your ignition module is going bad and needs to be replaced??? But if you do that remember that key will be different form the door and truck key if you go that route.
Add to Russet's Reputation
Old 08-24-2014, 01:09 PM   #3
2000_Titan
2000_Titan is on a distinguished road
Mine comes out in any position, too. Then the Service light comes on until I shut the car off and turn it back on. Always struck me as odd but hasn't cause any issues yet. Just curious if we know if this is by design? I doubt it with the service light, but I know some trucks are designed to do it.
Add to 2000_Titan's Reputation
Rate the quality of this post and help 2000_Titan reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
2000_Titan is offline   Reply With Quote
Old 08-24-2014, 03:33 PM   #4
The ignition key being removable simply means the lock cylinder or key is worn out. The simplest solution to troubleshooting - replace the ignition key with a new one made by GM (not the local key cutter) using the VIN to ensure a new key is made. Copying a worn out key simply copies a worn out key. A new VIN ign key made by GM is still cheaper against replacing the lock cylinder if its worn out. Vehicle ignition keys are not supposed to be removable in any position except OFF.
Have You Experienced the Ignition Switch Issue? Charlie Ion General 60 08-17-2015 11:12 AM
2004 vue ignition switch issue haloelite482 Vue Tech 3 02-14-2014 03:33 PM
Ignition Switch Issue.... AJEsquire Vue Red Line 14 04-23-2013 09:43 PM
2007 Ion startig issue (not ignition switch!) James614 Ion Tech 9 04-03-2013 09:21 AM
'94-SL1 - ignition key in switch chime - ignition switch bezel question wrchism S-Series Tech 1 01-24-2005 01:09 AM
