Old 06-04-2014, 10:47 AM   #1
abanerus
abanerus has a spectacular aura aboutabanerus has a spectacular aura about
2002 L-Series 2.2L Wagon
Default DexCool replacement
My 2002 LW200 came with DexCool at 80K miles. Should I flush it properly & replace with green coolant since I have heard DexCool damages gaskets?
Please advise.
Add to abanerus's Reputation
Rate the quality of this post and help abanerus reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
abanerus is offline   Reply With Quote
Old 06-04-2014, 11:04 AM   #2
billysvue
Default Re: DexCool replacement
The dexcool was new at 80K? HOw many miles now? HOw much time?
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Add to billysvue's Reputation
Old 06-04-2014, 11:18 AM   #3
Is your cooling system contaminated, damaged from using Dexcool? If its still red then ignore the scare tactics and rumor mongers of Dexcool damaging cooling systems from ignorance of facts. If Dexcool were so poorly used and a bad product then why is it still sold over the counter and copy cats duplicating its ability to last 5 yrs/150k miles? Either shrewd marketing is continuing a big lie or you're not doing any research into the Dexcool issues. There are none because of misapplication.
Dexcool is made for a totally enclosed cooling system running without air circulating inside, the reason for sludging. Dexcool is not for use in older cooling systems using the radiator caps on radiators - these allow air back into the cooling system as the engine cools off and as mentioned, sludging occurs when air is allowed to mix with Dexcool. All Saturns using the plastic coolant container close off, sealing the cooling system, leaving a small bubble of air in the container for normal coolant expansion/contraction without causing sludging. My car is over 10yrs old and due for a third Dexcool flush/replace - remaining red since the car was new. No sludging, no cooling system problems, nothing. Millions of GM cars, truck, suv's are using Dexcool without issues. The ones that started the Dexcool lawsuits were from older radiator systems that never sealed the cooling system from venting back as coolant cooled. Your system is sealed and only needs a visual inspection without removing the cap to check on coolant level. A good cooling system that doesn't leak won't be affected by Dexcool.
If you are truly worried then flush the cooling system at least once with water before using your choice of antifreeze. Ignoring a flush simply means not having the advantage of long life coolant mixed with less costly coolant with a shorter life, compromising the ability of long life coolant to provide long term protection.
Old 06-04-2014, 12:00 PM   #4
abanerus
Thanks guys, no way to tell how old the coolant is or when it was replaced except I put 10K more on it so its now 90K. Coolant looks slightly dull pink through cloudy plastic reservoir.
The car had some dry rot on exposed plastic & rubber parts from standing long in the sun that I have either fixed or replaced. Will pinch & check the radiator hoses & let you know how they are.
Old 06-05-2014, 06:34 PM   #5
Russet
2002 L-Series 3.0L Sedan
Please advise.
Stay with the DexCool that came with your Saturn for a reason not for looks or being different as Fdryer says there is a reason for it. Those others want to see you carpet baggar price and stay away from them as they obviously don't know their auto repair. It does cost more for DexCool but remember if GM recommends it use it that's simple to remember. My two Saturns and GMC SVN use DexCool had to buy few jugs but that is the cost of ownership you learn to take care and use the right products for the maintenance and longevity of the vehicle.
Add to Russet's Reputation
Old 06-05-2014, 06:46 PM   #6
onefunkar
onefunkar's Avatar
2008 Outlook XR
2007 AURA XR
agreed. car designed for dex cool. why use anything else?
Add to onefunkar's Reputation
Old 06-05-2014, 09:36 PM   #7
billysvue
If the maintenance is questionable ,then by all means flush it out and put in new Dex and while you're at a few of those heater and other coolant hoses that are usually a pain to change when you least want to change them.
Or you canalways pack some ductape
'17 Suby Forester
Old 09-08-2015, 12:14 PM   #8
abanerus
Thanks guys, my mech says my Dex is still good for some more time.
Old 09-08-2015, 03:57 PM   #9
toggenburg
toggenburg's Avatar
If it looks dull pink, dexcool is orange in 2 of my vehicles that use it.
Maybe someone topped it off with red dexron III at some point.
Old 09-08-2015, 08:29 PM   #10
Deep6
Deep6 is a splendid one to beholdDeep6 is a splendid one to beholdDeep6 is a splendid one to beholdDeep6 is a splendid one to beholdDeep6 is a splendid one to beholdDeep6 is a splendid one to beholdDeep6 is a splendid one to behold
Deep6's Avatar
Toggenburg, the dex cool from a few years ago was bright red. When mixed with water and put in the cooling system looked a lot like cherry kool aid.
Later versions show up as orange. Also of note some of the diesels used a "hi-viz yellow" dexcool. I personally ran walmart's super tech 5yr/150k coolant which was yellow in my LS1 and it worked out great. When it is time to flush the coolant you may want to consider a thermostat change as my LS1 had a tired factory one that wasn't letting the car heat up fully.
2002 LW200 MT 145K "Rare 5-speed"
2000 LS1 AT 283K "Served us well since 2000"
1993 SL2 AT 155K "Also Gone but not forgotten"
2012 Honda CBR 250R 4.7K "She can't take this from me"
Add to Deep6's Reputation
Rate the quality of this post and help Deep6 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Deep6 is offline   Reply With Quote
Dexcool fdryer General Saturn Discussion 4 10-11-2015 07:43 AM
DexCool EdGs S-Series Tech 17 05-13-2012 07:47 PM
Dexcool houstontexanfan S-Series General 54 03-03-2010 12:55 AM
dexcool... chefdiz Vue General 21 06-07-2007 11:17 AM
Dexcool question scoter S-Series Tech 17 09-17-2004 10:31 AM
