Old 06-03-2014, 06:35 AM   #1
Darkone
Darkone is on a distinguished road
Dizzy Saturn sw2 misfiring and hesataiting
Ok so to begin with my problem. I believe my engine is miss firing. I got this car from a friend is a sw2 and has 200k plus mile on it. So here is my issue. When I first start her up no problem. Idle is a bit high 1,200 and in drive 1000. After a warm up and the needle moves up past the first white marker on the heat indicator it starts to miss and surge a little at idle. Once I start moving it take me pushing the pedals further down then I need to to get it moving and it hesitates. I get it to about 30mph let of the gas idle goes down to 1,600rpm. Know I can slitly put my foot on the gas and it will run smooth but after a few sec the idle will go back down and start to buck until I let of the gas. Then when it shifts at 35to 40 mph it will start to buck very wildly until I push the gas peddle down further then it surges from 1800rpm to almost 3000. Then it will drop about 300 rpm every time. I've put new plugs in, new coolant, new tps, and cts. I've cleaned the throttle body out. Lots of carbon in the intake. Then what bugs me is the obd1 PCM is not throwing any lights. Know I know my transmishion mount needs to be replace but I don't think it is the issue here.
Add to Darkone's Reputation
Rate the quality of this post and help Darkone reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Darkone is offline   Reply With Quote
Old 06-03-2014, 08:05 AM   #2
95sw2rustbucket
95sw2rustbucket is on a distinguished road
95sw2rustbucket's Avatar
1995 SW2
Default Re: Saturn sw2 misfiring and hesataiting
do a compression test and see what the numbers look like. I recently lost a cylinder (0 compression) and I had a burnt exhaust valve
Add to 95sw2rustbucket's Reputation
Rate the quality of this post and help 95sw2rustbucket reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
95sw2rustbucket is offline   Reply With Quote
Old 06-03-2014, 07:44 PM   #3
Darkone
Dazed Re: Saturn sw2 misfiring and hesataiting
Sorry I knew there was sompthing I forgot to mention this morning. I also hade compression cheated when I had the valve cover Changed. I've also replaced the fuel filter as we'll. I want to stay spark plugs or sompthing computer related myself. As it will run fine when I first prese the peddle then idle down and start bucking.
03 Ion misfiring, need help please mssybart Ion General 26 03-08-2014 08:35 AM
06 Saturn Vue v6 stalling and misfiring sixtyonenorth Vue General 13 07-09-2013 08:58 AM
2002 saturn sl1 misfiring BlindedLegacy S-Series Tech 3 04-14-2011 11:10 AM
99 sl2 misfiring #4 orionkc S-Series Tech 2 01-11-2009 10:00 PM
Ion misfiring ... again. Unlike a Bull Ion Tech 19 05-28-2008 09:27 AM
