Go Back   SaturnFans.com Forums > Models > Saturn Sky > Sky Tech
Old 05-21-2014, 12:26 PM   #1
Shadow_tek001
Shadow_tek001 is a glorious beacon of lightShadow_tek001 is a glorious beacon of lightShadow_tek001 is a glorious beacon of lightShadow_tek001 is a glorious beacon of lightShadow_tek001 is a glorious beacon of light
Shadow_tek001's Avatar
Default Blower motor not coming on
2008 Saturn Sky blower motor wont turn on.
I tested the leads going to it for voltage, and there was 12v but as soon as I put a load on the leads (a 12v bulb) it dropped to 0v.
The blower motor does not turn on at any setting - including high, which from what I understand is the resistor being bypassed completely. So now I'm a bit confused. I jumped the motor with a battery and it spun.....
help please!!! :-(
Edward
Add to Shadow_tek001's Reputation
Rate the quality of this post and help Shadow_tek001 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Shadow_tek001 is offline   Reply With Quote
Old 05-21-2014, 02:17 PM   #2
Default Re: Blower motor not coming on
Does this help?
Old 05-21-2014, 04:03 PM   #3
Shadow_tek001
Does this help?
When I get time to analyse it, it might...Thanks!
Edward
Old 05-22-2014, 09:27 PM   #4
Shadow_tek001
Does this help?
Nope..... I'm no engineer.... so while I do recognize some of this, I still can't figure it out.
Edward.
Old 05-23-2014, 05:29 AM   #5
Red (12v pwr) goes to the blower motor. I drew green lines to show the four(4) speeds/ways that connect the blower motor to ground thru four different paths, one is direct for high speed and the other three paths that go thru the resistor card to select three lower speeds. All four paths connect to ground somewhere in the console/HVAC area. While you say you measured for 12v on the plug, ground may be missing/corroded/burned/loose. Ground wires are usually black. Look carefully for blower ground wires. This wire may be burned with blistering on insulation if poor connections are found wherever its connected to the chassis.
Old 05-23-2014, 10:47 AM   #6
Shadow_tek001
Dude! thanks man, this helps a lot!
Edward
Old 05-23-2014, 01:01 PM   #7
This should be the connector to the blower and pinouts.
Old 05-23-2014, 10:59 PM   #8
Shadow_tek001
Well crap, it's the harness for the resistor pack....
Apparently a common issue, found the same issue on a solstice forum.
High speed control line is melted at the plug.
Thanks for the help!!
Edward.
Old 05-23-2014, 11:41 PM   #9
Shadow_tek001
Here's how I fixed it....
Works great now and cost nothing to fix it this way.
Edward
Blower Motor Robio L-Series Tech 2 02-18-2012 07:35 PM
Blower Fan coming on and killing battery Admiral Jedi S-Series Tech 5 08-25-2011 08:06 PM
Mildew smell coming from blower vents toggenburg S-Series General 6 07-15-2011 02:44 PM
Blower Motor? peach_eater S-Series Tech 10 08-05-2010 07:23 PM
HVAC Blower Motor Dying...can one fix motor? flyhop S-Series Tech 2 09-28-2006 09:08 PM
