Old 05-17-2014, 06:25 PM   #1
i5spiders
i5spiders is on a distinguished road
Default 2006 vue keeps dying
2006 Saturn Vue 4cyl keeps dying and takes over an hour of being off before it will start again. We just replaced the starter and have no money left for expensive diagnostic tests. When it does start, the power drops significantly but stays on if it's had a long enough rest. It's also extremely hot here now, not sure if that has anything to do with it.
Add to i5spiders's Reputation
Rate the quality of this post and help i5spiders reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
i5spiders is offline   Reply With Quote
Old 05-17-2014, 08:00 PM   #2
billysvue
Default Re: 2006 vue keeps dying
THe battery is how old and is it charged? Hot where? How many miles were last driven without stopping the engine?
Total miles? Transmission?
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Add to billysvue's Reputation
Old 05-17-2014, 08:54 PM   #3
i5spiders
The battery is less than a year old and we had it tested as we thought the battery was the problem. The testers said it was good. The total miles on the car are around 124,000. Not due for another oil change for another 1,000 miles. We had only driven 5 miles when the car first messed up and we thought it was the battery. It simply wouldn't start or even turn over, even with a jump start. They checked the battery, said it was fine. That's when we replaced the starter and now it'll start but won't drive for more than a few miles and needs over an hour of cooldown before it will stay on. Basically, the engine turns over but then the power dies and the engine turns back off. Hot wise, I meant in california it's hitting 100 degrees for the first time and I thought now the solenoid was overheating or something.
Old 05-17-2014, 09:08 PM   #4
billysvue
Originally Posted by i5spiders View Post
We had only driven 5 miles when the car first messed up and we thought it was the battery........... I thought now the solenoid was overheating or something.
FIve miles after buying it? How many miles have you driven it since purchase? What trans?
'17 Suby Forester
Old 05-17-2014, 10:44 PM   #5
i5spiders
No, we bought the car a few years ago at 67,000 miles. It's an automatic trans.
Old 05-18-2014, 07:08 AM   #6
jrw1621
jrw1621 will become famous soon enough
2003 VUE 2.2L
In this picture shown, the black part is the ignition coil. The silver part is the Ignition Control Module (ICM)
Old cars had spark plug wires and a distributor. Our cars (and most newer cars) do not have plug wires; rather, Ignition coil. Instead of distributor; ICM.
I suspect the ICM. These can be gotten at auto parts stores for $60.
Personally, I spent $24 at a Pull-it-yourself junkyard for both the black and silver, combined when my 2.2L was running rough and down on power.
I wrote more on the topic in this thread:
http://www.saturnfans.com/forums/sho...d.php?t=200473
I that thread, the gentlemans car would not start.
In my issue, the car would run but rough and weak,
In your issue, the car will not stay running but I think all are versions of "bad" Ignition and this is the module controlling that.
Add to jrw1621's Reputation
Rate the quality of this post and help jrw1621 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jrw1621 is offline   Reply With Quote
Old 05-18-2014, 12:23 PM   #7
i5spiders
Thank you. I will check it out and let you know if that turns out to be the problem.
Old 05-20-2014, 10:52 PM   #8
i5spiders
Looks like it might've been the icm. When we went to change the starter originally, the battery was disconnected for so long that it went back to factory settings and that messed up the timing. So we tried to correct it and we also cleaned every valve we could find, including the Throttle Body, and after a bunch of crap flew out the exhaust, it seemed to be running fine. We're going to test run it for a few days, but if it starts stalling again, I'll be back.
Old 05-21-2014, 12:03 AM   #9
vasy
vasy is on a distinguished road
2007 VUE Green Line
Don't forget to re-learn the idle.
The the key on, leave for a minute but don't start the car, turn it off. Start the car.
Add to vasy's Reputation
Rate the quality of this post and help vasy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
vasy is offline   Reply With Quote
Old 05-21-2014, 05:24 AM   #10
jrw1621
2003 VUE 2.2L
Did you actually put in a different icm?
I am confused by what you have written here.
Your issue was that the car would not continue running. The starter only functions to start the car. The starter has no function in keeping the car running so I am unclear why the starter was suspected.
I also do not think that having a battery disconnected will cause any changes to timing? I am confused by this statement.
911 Car Keeps Dying dmax03 L-Series Tech 4 12-11-2009 12:50 AM
Car dying cosmo185 S-Series General 9 03-23-2008 07:22 PM
Car dying help??!! gallar2 L-Series Tech 4 08-02-2007 12:31 PM
Dying SC2 fastfishy S-Series Tech 8 12-02-2004 06:49 PM
Car dying, Help! Tmac S-Series Tech 21 05-27-2004 12:33 AM
