Old 05-03-2014, 03:20 PM   #1
the_tim
the_tim has a spectacular aura aboutthe_tim has a spectacular aura about
2001 SL2
Default Thanks, you saved my SL2! (emission tests, ECTS / thermostat)
I just wanted to drop a line in here to thank everyone for their contributions. I was having issues with my 2001 SL2 throwing an OBDII code. I fixed the faulty O2 sensor (thanks to the great info on these forums). Then some of the car's internal emissions tests weren't completing, so I was back.
Thanks to even more of the wealth of knowledge here I realized that the tests weren't completing due to low engine temperatures due to either a faulty ECTS Coolant Temp Sensor or thermostat, so I ordered the Stant 14279 and a new brass ECTS. After replacing both parts and taking a couple more drives, all the tests completed and I was able to pass WA emissions (side note: turns out WA doesn't care about the Evap Test, which was the one that took the longest to complete).
I also realized that the low temperature (needle never got above 1/4) was causing my engine to idle high (~2k RPM when I pushed in the clutch and coasted on the freeway, vs. ~1k normal). With the new ECTS and thermostat that problem went away and my MPG is back up to where it was before.
So anyway, I just wanted to say thanks! This forum is invaluable.
Enjoy the attached photo of the old ECTS next to the new one. Eww.
Add to the_tim's Reputation
Rate the quality of this post and help the_tim reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
the_tim is offline   Reply With Quote
Old 05-03-2014, 03:26 PM   #2
SL19302
SL19302's Avatar
2002 SL1
Default Re: Thanks, you saved my SL2! (emission tests, ECTS / thermostat)
Thats one of the worst ones I have seen yet! Glad you got everything straightened out.
CHECK YOUR OIL!
Add to SL19302's Reputation
Old 05-03-2014, 03:49 PM   #3
the_tim
2001 SL2
Yeah from the looks of it this was the first time it had been replaced in the car's 180,000+mile lifetime. I didn't take a picture but there was also a big pile of blue-green corrosion under where the sensor sticks out of the engine.
2001 Saturn SL2 - 205,000 miles and counting
Old 05-04-2014, 10:36 AM   #4
el diablo viejo
el diablo viejo's Avatar
1994 SW1
Even though it appears to be working ok, hopefully you at least sprayed out the connector with some electrical contact cleaner before plugging it back on ?
97 sl2 a/t 104 K
Add to el diablo viejo's Reputation
Rate the quality of this post and help el diablo viejo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 05-04-2014, 04:53 PM   #5
the_tim
2001 SL2
Yeah after seeing how bad it was I did my best to clean out the connector before putting everything back together.
95 SC1 ECTS and thermostat help andrewwellen S-Series Tech 4 03-03-2013 02:40 PM
Do I need a new ECTS or thermostat? sl47k S-Series Tech 5 04-11-2012 08:53 AM
ECTS + thermostat MKR S-Series Tech 12 04-27-2011 03:49 PM
New ECTS + New Thermostat AceDerry2 S-Series Tech 2 02-06-2007 09:54 AM
ECTS vs. Thermostat? joshjani S-Series Tech 5 03-16-2005 11:27 PM
