Old 05-01-2014, 01:43 AM   #1
Dake
Dake is on a distinguished road
Default Temp gauge change
After having a new water pump and serpentine belt put on my 98 SL2 the temp gauge now reads above the 1/4 line on the gauge, before the new water pump the gauge read below the 1/4 mark when driving around town. Any ideas why the change? Thanks
Add to Dake's Reputation
Rate the quality of this post and help Dake reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dake is offline   Reply With Quote
Old 05-01-2014, 02:02 AM   #2
el diablo viejo
el diablo viejo's Avatar
1994 SW1
Default Re: Temp gauge change
The thermostat or ects must have been replaced also. Running at 1/4 on the gauge usually indicates a failed thermostat. Correct reading should be 3/8 to just below 1/2, so it sounds like you are where you should be.
97 sl2 a/t 104 K
Add to el diablo viejo's Reputation
Rate the quality of this post and help el diablo viejo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 05-01-2014, 06:10 AM   #3
Signmaster
Signmaster is a name known to allSignmaster is a name known to allSignmaster is a name known to allSignmaster is a name known to allSignmaster is a name known to allSignmaster is a name known to all
Either the above took place, or the flow change moved the gauge. It's not uncommon for less flow to give greater cooling in factory systems. Though in theory the thermostat should compensate, under drive pulleys often move the temp gauge down. If you had bad corrosion or flow problems with the water pump, you may have gone from less flow to normal flow and thus sped things up.
Old 05-01-2014, 07:25 AM   #4
SL19302
SL19302's Avatar
2002 SL1
You need to Replace your Coolant Temp sensor to the Brass Sensor and Replace the Thermostat, I usually do these as a pair everytime, These should have been replaced with the Waterpump due to the current readings that you had on your gauge.
CHECK YOUR OIL!
Add to SL19302's Reputation
Old 05-01-2014, 01:32 PM   #5
Dake
Thanks for all the great Info.
Old 05-01-2014, 01:39 PM   #6
Dake
The temp gauge on another family owned 98 SL2 is always just below the 1/4 mark driving around town unless it get really warm, then it moves above the 1/4 mark. So it sounds like that car is the one that need a new temp sensor and coolant flush. Thanks again for all the Info. Great site, I have got to say that the cool sounds that the SL2s make is why I like them so much.
Old 05-01-2014, 08:27 PM   #7
Signmaster
If the ECTS is bad it will create a rich mixture and keep temps lower than usual. The thermostat will often keep temps down, but not have as much effect on mixture. Usually ECTS will rob MPG more due to that.
If in doubt, use a scan tool or meat thermometer in the reservoir to determine actual operating temp vs gauge. Some people get a lower reading on the gauge even with operating temps in the normal ranges. They are far from precise, and combined with the sensor variation for any given actual temp, the gauge position isn't a given.
There was a member not long ago that switched his thermostat and ECTS only to find the gauge stayed on 1/4 or slightly above anyway. Checking actual temp first can save you money, and checking actual temp vs sensor reported temp verified ECTS is working properly.
air cond. fuel gauge and temp gauge not working. Help?? brielle L-Series General 12 09-14-2016 08:07 PM
Temp gauge not moving, replaced ECTS, no change... Ilwakeboarder87 Vue General 8 01-03-2014 10:46 PM
low temp gauge. chris015 S-Series General 6 11-19-2013 04:04 PM
Outside temp gauge farmasis Outlook General 10 05-29-2007 07:58 PM
SL1 temp gauge... spitbits1500 S-Series Tech 2 10-16-2005 07:35 PM
