Old 04-28-2014, 10:15 PM   #1
minttoothpaste
minttoothpaste has a spectacular aura aboutminttoothpaste has a spectacular aura about
Default Sudden Slam Shift Problem
Hi - I'm a long time lurker and the site has helped me troubleshoot quite a few issues but I finally had to join to figure this out. I've got a 2002 SC2, DOHC, Auto, 130k.
I just started experiencing a slam shift problem. Never had any tranny problems until this. In fact the car was perfectly fine until accelerating away from a stop and then it just experienced a bone jarring shift and has been doing it since. I've got it parked now because I'm afraid of permanent damage (its so harsh, its actually uncomfortable to drive). It slams in all forward gears and reverse. 2-3 and 3-4 slip a bit but slam eventually. There was no reverse slam before this or any other sign of trouble.
Tested the solenoids, they appear to be fine. Checked the input shaft nut, its fine. Took it to a local transmission shop, he put it on the computer - no codes (No SES light either). He said possibly the clutch packs but he would have to open the transmission up (which would cost me).
The only common thing I can think is the valve body. However, this came on suddenly without warning and affects all forward gears and I'm under the impression that the valve body issue is a gradual problem that affects reverse only. So what do you guys think??
Add to minttoothpaste's Reputation
Rate the quality of this post and help minttoothpaste reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
minttoothpaste is offline   Reply With Quote
Old 04-28-2014, 10:47 PM   #2
Madness10
Madness10 will become famous soon enough
Madness10's Avatar
Default Re: Sudden Slam Shift Problem
This happened to me also in my 99SL2. Never had a problem, then all of a sudden, slam, big time. Parked the car, went to the junk yard, pulled another VB and 1 hour and 60.00 later, everything is good. Sometimes, these things just happen.
Add to Madness10's Reputation
Rate the quality of this post and help Madness10 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Madness10 is offline   Reply With Quote
Old 04-29-2014, 03:58 AM   #3
Pitcher
Pitcher's Avatar
You need a valve body.
Get one with the Sonnex upgrades from either Special Forces (on here) or Ken Partin on eBay.
Get it done before you loosen up that Input Shaft Nut or you'll triple your work!
'98 SC2 Rare "Red Hot" 5-Speed. Castrol Edge EP
Taking Care of a '01 SL2 10th Ann. Ed. "Silver Salute" Mobil 1 AFE
Add to Pitcher's Reputation
Rate the quality of this post and help Pitcher reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 04-29-2014, 10:16 AM   #4
billr
Just be aware that neither Special Forces or Ken Partin do both Sonnax upgrades (the pressure regulator and booster valves). Decide which upgrade you want and order from the appropriate vendor.
Add to billr's Reputation
Old 04-29-2014, 12:28 PM   #5
minttoothpaste
Thanks guys. I went and ordered a valve body. Hopefully that will fix it.
Old 05-03-2014, 08:26 PM   #6
minttoothpaste
Well, I installed a new refurbished valve body. But now the vehicle won't start. It cranks and cranks and cranks but doesn't start. I assume the security system has something to do with this.
Old 05-06-2014, 07:22 PM   #7
minttoothpaste
The new valve body fixed the shifting right up. It slammed until the computer "relearned" to shift with the new valve body (which had me worried for a bit). Thanks for the advice guys.
Old 04-17-2016, 02:01 AM   #8
allterrain08
allterrain08 is on a distinguished road
How long did it take the computer to learn there was a new valve body? Just replaced mine and it seems to still being having issues shifting
Add to allterrain08's Reputation
Rate the quality of this post and help allterrain08 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
allterrain08 is offline   Reply With Quote
Old 04-17-2016, 06:46 AM   #9
Chazberry
Chazberry's Avatar
Who did you get the VB from?
Add to Chazberry's Reputation
Old 04-17-2016, 08:33 AM   #10
1996SL11.9L
1996SL11.9L's Avatar
2002 SL1
I put a new sonnax VB on my old 96 SL1 and it took about 35-45 miles to get all the shifts figured out. I drive 64 miles round trip to work and about 5 miles into my drive home the slam shifting in all gears was gone. The up shift into 4th was the last to get corrected.
1996SL11.9L is online now   Reply With Quote
new valve body- slam shift returns intermittently! saturnrookie S-Series Tech 18 10-31-2017 07:56 PM
99SL2 Reverse Slam and Strange shift from 2nd - 3rd N80727 S-Series Tech 3 05-12-2013 06:12 PM
reverse slam.....in D doesnt shift? pmondo S-Series Tech 9 02-08-2012 11:56 AM
Slam shift only after thorougly hot 2000 SL1 facility S-Series Tech 8 08-02-2011 08:29 AM
92 sc2saturn transmission slam - shift to d2 benhoffman S-Series Tech 6 09-22-2009 06:12 PM
