Old 04-27-2014, 04:08 PM   #1
jessicag89
jessicag89 has a spectacular aura aboutjessicag89 has a spectacular aura about
Default Drivers Power Seat stuck!!! 03 L300
While on break, I figured I would recline back and put my seat all the back so I could lay back. After about 40 minutes, I went to put the seat back and nothing happened. NONE of the buttons work anymore! I cant go forward or put the recline back up. The UP/down button thats also on the side of the seat is stuck. I cant push the Up button down at all. Like its jammed. The recline and forward/back buttons can be pushed but nothing happens.
Whats going on? How can I fix this? Is it a fuse?
2003 Saturn 300
Drivers side power seat
Add to jessicag89's Reputation
Rate the quality of this post and help jessicag89 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jessicag89 is offline   Reply With Quote
Old 04-27-2014, 04:19 PM   #2
rb6667
rb6667's Avatar
2004 L-Series 2.2L Wagon
2004 L-Series 3.0L Wagon
Default Re: Drivers Power Seat stuck!!! 03 L300
Yes, This seat is fused. Look on the passenger side kick panel fuse box. Even if the fuse looks good, it would not be a bad idea to replace with another one of the same rating. Since this fuse is hot/live all the time, disconnect your battery before you remove this fuse.
The other possibility is that the seat switch is bad. Try the fuse 1st and report back.
Add to rb6667's Reputation
Old 04-27-2014, 06:01 PM   #3
jessicag89
Will pick up fuses and switch it out tomorrow morning. Ill report the status!
Old 04-27-2014, 06:53 PM   #4
rb6667
rb6667's Avatar
There is another option. I'm pretty sure the power seat fuse is 20 amps. Look and see if there is another non critical system that will allow you to "Borrow" that 20 amp fuse for this test.
If you have an owners manual, it will show you what other systems are protected by a 20 amp fuse. Removing a known good 20 amp fuse from another slot, may allow you to test it now without going to the auto parts store.
Do not try and start or drive the car while you have this "Borrowed" fuse removed. Remember, the power seat fuse is hot all the time so there is no reason for you to even try and start or drive the car.
Old 04-28-2014, 02:49 PM   #5
jessicag89
It was the fuse! Thank you!
Old 04-28-2014, 03:08 PM   #6
rb6667
rb6667's Avatar
Don't you just love it when a plan comes together? It would be a very good idea to keep a good selection of various amp fuses in your glove box.
Glad it was something simple.
Old 04-29-2014, 09:14 PM   #7
born again
born again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of light
2000 L-Series 2.2L Wagon
Blown fuses are not normal. When one blows, you want to know why. In this case, you may have held the button down too long to get the seat all the way down. When the motor stalls, it uses a lot more current.
Add to born again's Reputation
Rate the quality of this post and help born again reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Mesh Support under drivers seat... (common caved in drivers seat) mattachuz L-Series General 8 02-12-2012 05:22 AM
my drivers seat is stuck 96sl1daily S-Series General 5 03-19-2011 02:17 PM
L300 Power Seat Problem Urbanrover L-Series General 3 05-28-2010 03:14 PM
Stuck drivers seat adamthered S-Series Tech 6 02-17-2010 11:34 AM
Problems with bump in Drivers Power Seat BoA Vue General 4 02-17-2005 12:36 PM
