Old 04-27-2014, 06:45 AM   #1
merlinm80
merlinm80 is on a distinguished road
Default 2008 Outlook XR master window switch
I am trying to replace the master window switch on my outlook, but I cannot figure out how to pry the trim piece loose to get to the switches without breaking off the clips. Any advice?
Thanks.
Add to merlinm80's Reputation
Rate the quality of this post and help merlinm80 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
merlinm80 is offline   Reply With Quote
Old 04-27-2014, 07:46 PM   #2
Penrod
Penrod has a spectacular aura aboutPenrod has a spectacular aura about
Penrod's Avatar
2009 Outlook XE
Default Re: 2008 Outlook XR master window switch
What's wrong with the switches? Will they not roll the windows up and down?
Add to Penrod's Reputation
Rate the quality of this post and help Penrod reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Penrod is offline   Reply With Quote
Old 04-30-2014, 11:09 PM   #3
eyberz
eyberz is on a distinguished road
Hi I too have a 2008 Saturn outlook and my drivers side window switch went out. ..I ordered the part online for $60 and was going to try to do it myself but started and felt like I was going to break something. .. called a local cat audio installer and asked them how much they world charge to replace and install and they said $15-$25 at the most... you might want to try that route.. hope this helps
Add to eyberz's Reputation
Rate the quality of this post and help eyberz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
eyberz is offline   Reply With Quote
Old 05-02-2014, 12:21 AM   #4
Penrod
Penrod's Avatar
2009 Outlook XE
In my 09 outlook XE the switches weren't working or were very intermittent. I gently pried the part out and cleaned the contacts and it works fine now. I did break a piece in the back door panel cause I didn't realize there was a screw holding those ones in. It still works it's just doesn't have that extra screw holding it in.
How do you test master window switch wylde8 S-Series Tech 1 06-18-2009 06:54 PM
Window regulator/master switch 2000satty2 S-Series General 4 12-23-2007 08:33 AM
Master Window Switch swap? digiforce S-Series Tech 1 07-10-2007 03:45 PM
does anybody need a 96-99 SL/SW master power window/mirror switch (console)? brenspin S-Series General 0 01-15-2007 09:20 PM
Master Window Switch - Contacts Too Worn Out Leadsled Coupe S-Series General 6 09-27-2005 12:36 PM
