Old 04-26-2014, 10:59 PM   #1
claregina
claregina is on a distinguished road
Default Can U solve my SC1 MYSTERY
I have a really good 1999 SC1 Mystery. Please solve if you can.
Here are my consistent problems:
1. Starts Cold but not when temp is past 1/4 mark.
2. Code: Multiple Misfires
3. Runs smooth like kitten when cold. When it nears 1/4 temp mark it starts running really rough. Can feel the difference and muffler sound like outboard boat motor.
4. Idles up and down by -300/+300 RPM when near or at the 1/4 temp mark.
5. Will start to overheat when stopped for too long or left in park for awhile.
I have replace the following:
spark plugs, Ignition wires, Fuel pump, fuel filter, Both Ignition Coil Packs, Ignition Control Module, Crankshaft Position Sensor.
I have also cleaned the Throttle body and its sensors. Also cleaned all the injectors. Cleaned the MAP.
Thoughts?
Add to claregina's Reputation
Rate the quality of this post and help claregina reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
claregina is offline   Reply With Quote
Old 04-26-2014, 11:03 PM   #2
Default Re: Can U solve my SC1 MYSTERY
Replace the ECTS and inspect the 2 wires for any splices. If you find any cut them out and properly solder and heat shrink them.
Check the exhaust system for leaks this way.
Exhaust leak check.
--Locate a low pressure high volume air source, reversible vacuum cleaner, large fan, leaf blower or what ever you can find.
--Loosely couple to cold exhaust at the tail pipe, or direct fan at tail pipe.
--Spray every inch of the exhaust between the head and CAT inlet with a mixture of 2 or 3 drops of dish soap and water in a spray bottle.
--Pay close attention to the lower flange, lower support clamp, and flex connector.
--The flex connector is under the protective braid so it requires quite a bit of solution to show any leaks.
If you replaced the OEM fuel filter with anything but a WIX 33731 you will eventually have fuel pressure problems. http://www.rockauto.com is the low cost parts source.
Help Solve Electrical Problem? kimlou45 General Saturn Discussion 1 07-02-2012 10:06 PM
Help me solve my vibration problem please! Beerme S-Series General 9 04-15-2009 08:15 PM
Very interesting little problem with an sl1... can you solve it? acr2001 S-Series General 6 10-11-2005 12:32 PM
Solve Two Problems in One Thread (Hopefully) NashvilleRider S-Series Tech 4 04-19-2005 09:43 PM
