Old 04-13-2014, 02:31 PM   #1
2003vue
2003vue is on a distinguished road
Default intermittent engine oil leak
2003 Vue 6 cyl. 3.0 -
I have an oil leak, about the size of a quarter, for 2-3 days in a row.
Then it stops for a few days. Then starts again.
It drips off from front of engine, slightly toward passenger side of center.
I see some wetness around the valve cover gasket, but this should be a constant leak.
I have replaced the oil pressure switch; no leaks. No leaks from oil filter housing.
My guess is that the v.c. gasket leaks down into a small collection area, where it 'stores up' for a while. When the pool fills, and/or fast/bumpy driving, the pool drains down to garage floor.
Thanks for any suggestions!
Add to 2003vue's Reputation
Rate the quality of this post and help 2003vue reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
2003vue is offline   Reply With Quote
Old 04-13-2014, 05:38 PM   #2
far2grumpy
far2grumpy's Avatar
Default Re: intermittent engine oil leak
Even cam cover gaskets in excellent condition tend to get pushed out of place (perhaps temporarily) if crankcase ventilation system does not maintain internal vacuum.
Problem would be worse during very cold weather (PCV hose freezes) or when you do a lot of low RPM driving.
There's at least one hose (and possibly two) leading from throttle body to the crankcase breather - located on transmission end of engine - cylinder bank nearest windshield.
One way (according to FSM) to verify system is operating normally is to remove oil dipstick - rev engine above 1500 RPM and check for vacuum at dipstick hole.
Intermittent Oil Leak? jbaron76 L-Series Tech 10 03-02-2012 11:02 AM
Intermittent engine knock: OCD kicking in mfedenko S-Series Tech 1 02-15-2011 09:11 PM
Intermittent engine surge Greg1964C S-Series Tech 14 12-21-2009 12:50 PM
Engine Pinging Intermittent rush2112 S-Series General 14 04-01-2008 04:38 AM
Intermittent Check Engine Light SL2 JohnnyRudick S-Series General 7 11-27-2007 06:58 PM
